Recording Device volume resets to 100 after program launch
    England
    Windows 8.1 Professional
    Hello, I recently went and purchased an AT2020 and Behringer Xenyx Q502USB Audio Interface to improve my video's but when I go onto TeamSpeak it's ok but then every time I launch CS:GO the volume resets to 100 and I have to tab out and go into my Recording Device and edit the level back to 65 is there anyway to fix this or lock the volume?
    Hi Alex, I Would suggest you to check device usage setting under recording device, just follow below steps to check device usage setting
    Go to Control Penal -> Click on Sounds -> Then Click on Recording Tab -> Click on Properties
    Microphone properties Window will appear on your screen then check device usage setting if it is disable then enable it.
    Hope it will solve your problem. Good Luck!!
    England
    Sorry for the late reply this did not work however I found another thread on the steam community and I tried it but now the opposite happens and my recording device volume resets to 0 volume every time I load the game.
    *Since then I reinstalled steam and my game but it's now resetting back to 100 volume*
    This sounds like an application caused problem, rather than an actual "sound" problem.
    Posting in the gaming section may be the best forum section for this.
    https://www.eightforums.com/gaming/
    England
    Thanks sorry I didn't know there was a gaming section but thanks for the help!
    Unfortunately some application software is poorly written and will do things like this. In those cases, there is nothing you can do but manually change it yourself after running that application/game or whatever.
Yesterday I got a new microphone and I set up the audio interface and it was still to loud so I right clicked on the speaker (bottom right) and changed the recording device audio to a certain volume however after a few hours it resets to 100% volume how can I fix this issue?
I leave the house, all is well. I come back and I can't use my default mic, and the Digital Audio is maxing out. I didn't change anything on the pc. How do I debug this beyond the basic Recording Devices properties fiddling, rebooting, disabling, driver checks? The desired mic is a...
Looking for a audio recorder/grabber to record audio that i play from my computer.. believe it or not, i used to be a mac user and used programs like audio hijack and etc.. now i'm with windows 8.1 and what the heck do i use to grab high quality audio and save it to high quality files on my...
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
Hi All I am desperately trying to save some very old audio cassettes by transferring them to my computer before it is too late. I am running Windows 8 on a Lenovo G500.I am using a Behringer UFO202 digital audio interface into which I can connect my analog cassette deck and run directly...
Event Viewer Not Recording Program Open in Performance & Maintenance
I have an sound assigned to the Open Program event. About every half hour a program opens and triggers the event sound. But, I can't seem to catch what program it is using event viewer. I mark down the time but no matter what filter I use I never see the event for that particular time. Currently I...
I have tried lots of things to try to solve the problem, but to no avail. Please if you know anything that will help solve my problem please let me know. Thank you!:D
