my headphones make a buzzing sound when plugged in
    Windows 10
    This isnt a headphone problem its a computer problem anyone know how to fix it?
    really man?
    there are so many factors involved.
    it could be the power plug you have plugged into.. the wall outlet/socket.. that causes buzzing..
    plug the headphones into other sources and if you notice buzzing.. cdplayer/iphone/ipod..
    then when did this start? is it all headphones? have you tried different headphones?
    there isn't much to do inside windows but tweak sound settings.. and make sure your sound drivers are the latest... if you have a Realtek audio card etc.. which of course you like many others don't tell us what you have..
    It's most likely something power wise causing buzzing.. do you live in an old house?
    or the components inside your computer are interfering... from bluetooth to the fan running inside the computer..
    I'm guessing power but How to do anything with power except set grounding and voltage levels? which you definitely shouldn't do with your computer..
    and then I would NOT particularly tweak these settings but.. things like
    Windows 10
    Quote Originally Posted by brooksndun View Post
    really man?
    Well I have tryed Different headphones and I have changed the plug but it still buzzes.
    play a song or video ... MAKE sure you HEAR THE BUZZING IN HEADPHONES..
    then unplug your "special" mouse and keyboard and all devices ... usb's etc.. and see if the buzzing goes away... and then also once you have all devices unpugged, try pluggin in the headphones again and see if there is buzz..
    things like that man..
    windows doesn't have a "buzz" in headphones option or setting.. so it's clearly hardware or power related.. and even could be a faulty jack..
    google how to clean headphone jack computer etc..
    but don't ruin your headphone jack either with chemicals!
    also make sure the headphones are inside the jack properly and then restart your computer.. etc.. try stuff.. but educated guesses on things..
    are you using a big 90 inch Plasma TV near the computer etc..
    Windows 10
    Thanks dude so much! It was my USB ports... i just plugged my ketboard and mouse into a USB 3.0 Port and it stopped! Love u <3!
    well just give me a thumbs up then.. ha.. glad you got it..
Whenever i plug in my headphones, i hear a buzzing noise. its not the headphones problem, i tested them on other devices and there was no problem. I even changed speakers but i still have the prob, Please Help, ty. :(
Good morning. I am running Windows 8.1 with 8gb of ram, Time Warner internet at 50mbps (speed tested before I posted). 2gb video Nvidia card. Using on board sound (no extra sound card) Last night, I could only get sound on my speakers whenever I plugged in my headphones. Today, none of my...
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Dear all, I've been facing an issue with my sound lately (potentially linked to the win 8.1 update - as seems to be the case of a lot of people); I'm unable to get my sound to work, and I'm getting the following error message: "No speakers or headphones are plugged in". I've been trying out a...
Hi friends, I am using Windows 8. I am facing an issue with my sound all on a sudden. The volume icon on the task bar has a red cross on it. When I hover on that it says 'No speakers or headphones plugged in' (attachment-1). When I click on the icon I get a screen like attachment-2 which...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
Hi everyone, I have an interesting problem: On my laptop (Lenovo Y510p) I can hear a buzzing/whistling/noise sound while my headphones are plugged in. The problem goes away when I mute my sound, but this buzzing can be heard while booting as well. This led me to believe that my problem is...
