Solved my headphones make a buzzing sound when plugged in
Epic24
This isnt a headphone problem its a computer problem anyone know how to fix it?:D
    Windows 10
    core i7 4820
    16 GB
    GTX 770
    Deathstalker
    Deathadder Chroma
    Chrome
really man?
there are so many factors involved.
it could be the power plug you have plugged into.. the wall outlet/socket.. that causes buzzing..
plug the headphones into other sources and if you notice buzzing.. cdplayer/iphone/ipod..
then when did this start? is it all headphones? have you tried different headphones?
there isn't much to do inside windows but tweak sound settings.. and make sure your sound drivers are the latest... if you have a Realtek audio card etc.. which of course you like many others don't tell us what you have..
It's most likely something power wise causing buzzing.. do you live in an old house?
or the components inside your computer are interfering... from bluetooth to the fan running inside the computer..
I'm guessing power but How to do anything with power except set grounding and voltage levels? which you definitely shouldn't do with your computer..
and then I would NOT particularly tweak these settings but.. things like
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
really man?
Well I have tryed Different headphones and I have changed the plug but it still buzzes.
    Windows 10
    core i7 4820
    16 GB
    GTX 770
    Deathstalker
    Deathadder Chroma
    Chrome
play a song or video ... MAKE sure you HEAR THE BUZZING IN HEADPHONES..
then unplug your "special" mouse and keyboard and all devices ... usb's etc.. and see if the buzzing goes away... and then also once you have all devices unpugged, try pluggin in the headphones again and see if there is buzz..
things like that man..
windows doesn't have a "buzz" in headphones option or setting.. so it's clearly hardware or power related.. and even could be a faulty jack..
google how to clean headphone jack computer etc..
but don't ruin your headphone jack either with chemicals!
also make sure the headphones are inside the jack properly and then restart your computer.. etc.. try stuff.. but educated guesses on things..
are you using a big 90 inch Plasma TV near the computer etc..
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
Thanks dude so much! It was my USB ports... i just plugged my ketboard and mouse into a USB 3.0 Port and it stopped! Love u <3!
    Windows 10
    core i7 4820
    16 GB
    GTX 770
    Deathstalker
    Deathadder Chroma
    Chrome
well just give me a thumbs up then.. ha.. glad you got it..
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
