How do I change audio playing jack output.
    Windows 7
    Hi to all !
    My computer is playing audio on green jack output on the back of the computer.
    But,i somehow broked it and it doesn't work anymore and I can't plug anything in it.
    So i am with no audio now.
    OFC i have other outputs with different colours ..
    How can I change that my computer don't play audio on green one,so it can play on orange one or what ever else jack output
    If you have a "Line Out" jack (generally Blue but could be another color on your PC) you can use that. If you have a headphone jack on the front you can use that for the speakers.
    Windows 7
    I don't have "Line Out' and I don't have front jack outputs.
    I am actually installed Windows 7 five days ago.
    Before that i was using XP ..
    On XP i was using orange one,because my green one doesn't work.
    I already request help on other forums but they said I need to definie one jack where will my computer play audio on it. (in control panel somewhere)
    How can I edit it and play my audio on orange one ?
    What sound driver do you have, the actual sound hardware driver or only the basic Windows installed High Definition Audio driver? If you do not have the actual sound hardware driver (and there is one that is Vista/Win 7 compatible) install that as it may allow jack defining (not all sound software will allow you to define the jacks).
    Please fill in the "My System Spec's". It helps us to try and help you.
    Windows 7
    I have installed driver. It is Realtek.
    Realtek HD Audio Manager.
    Does your version allow reassigning jacks? Some do and some do not.
    If not, the best option is to either use a USB connected sound card or install a separate sound card. You can get sound cards relatively inexpensive.
    Windows 7
    If u think about reassining in regedit it can i already tried it..But it doesn't work ..
    I think there is a better solution so I can definie it in control panel ..
    I don't recommend the registry. If it can't be done with the legitimate software, then the only option is either replace the motherboard or use a different sound card.
Solved audio jack pop-up in Sound & Audio
I used to have a pop-up whenever I plugged in something to my audio jack that asked what type of device I just plugged in(headphones,speakers,headset,etc) , but I disabled it. How do I enable it again?
My computer's front audio jacks do not work because they are not and can not be plugged into the the motherboard. However, my rear audio jacks do work. I recently bought a headset with a built in mic that had cables long enough to reach the back of my tower. Whenever I plugged them in, they were...
For some reason my audio and mic jack doesn't work at the front of the computer. I tried unplugging and replugging the F-Audio jack cable in my motherboard. I also have realtek "Disable front jack detection" checked off in the box. Any other advice to fix this? Thanks! Edit: The audio jack...
Well, I used my microphone on my laptop once to call a friend on Skype. Everything worked fine, even with my headphones plugged into the audio jack. But the day after, I try and do the same but my microphone isn't even working. After lots of frustration and trial and error, I find that it's the...
I just got my new laptop with Windows 8.1 a few days ago and everything worked fine until now. When I plug in my earbuds, only the left earbud works. I've tried nearly everything I found online but to no avail. I've tried reinstalling the Realtek HD Audio drivers and system restoring to the...
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
