i just bought some new headphones that are USB to replace my old one that was also USB and i am having the same problem where they will not play audio. i looked in the playback and they are checked under
Default Communication
but when i try to change it to default device it dose nothing. also it says no audio device installed under mixer but it is installed.(update) the problem is i have the headphones and I cant get sound from them. everything i check says there ready to use but because its on Default Communication and my speakers are on default device it wont let me use them and i cant change them to default device
"fireberd Is default communications device correct? Seems they should be detected as headphones.
What is listed in the Device Manager, Sound, Video and Game Controllers section? Is the headphones listed there?"
its listed under both audio input and output and Sound, Video and Game Controllers section
(update) just installed windows 7 out of preference and in doing so it fixed it thanks for trying to help anyway
- 64-bit Windows 8.1 build 9600
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom self built
- CPU
- intel i5
- Motherboard
- ASRock Z97 pro 4
- Graphics Card(s)
- EVGA Gforce GTX 970 sc
- Browser
- crome
