Recording device audio volume resetting.
    England
    Windows 8.1 Professional
    Yesterday I got a new microphone and I set up the audio interface and it was still to loud so I right clicked on the speaker (bottom right) and changed the recording device audio to a certain volume however after a few hours it resets to 100% volume how can I fix this issue?
    Could be a program is resetting it. Check for programs such as Skype, Chrome, etc.
    BTW, you have Realtek PC sound card.
    England
    So I should uninstall skype?
    No, I would not uninstall it. Just mentioned that Skype could potentially be something that may cause the issue.
    England
    Well... I went into the device properties and disable allows programs to take control of this device. So let's see how this works.
    England
    Didn't work.
    "Refresh" the sound driver. Go to the Device Manager, Sounds section, RIGHT click on the entry for Realtek and then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. This fixes a lot of problems and MAY fix yours.
    England
    I don't see the Realtek audio device.
    Maybe that is the problem. Based on your System Specs MSI motherboard, MSI lists Realtek as the sound hardware. If you only have "High Definition Audio Device" driver then the first step is to install the Realtek sound drivers.
    MSI USA 64
    See my Device Manager:
    England
    Do I click uninstall or disable?
Page 1 of 2 12 LastLast
I leave the house, all is well. I come back and I can't use my default mic, and the Digital Audio is maxing out. I didn't change anything on the pc. How do I debug this beyond the basic Recording Devices properties fiddling, rebooting, disabling, driver checks? The desired mic is a...
Looking for a audio recorder/grabber to record audio that i play from my computer.. believe it or not, i used to be a mac user and used programs like audio hijack and etc.. now i'm with windows 8.1 and what the heck do i use to grab high quality audio and save it to high quality files on my...
I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue. Things I've tried: The mic is not muted and the volume levels are maximized ...
Hi All I am desperately trying to save some very old audio cassettes by transferring them to my computer before it is too late. I am running Windows 8 on a Lenovo G500.I am using a Behringer UFO202 digital audio interface into which I can connect my analog cassette deck and run directly...
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
Audio Recording Issues in Sound & Audio
I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1 I am having one problem, most likely user error. When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very...
I have tried lots of things to try to solve the problem, but to no avail. Please if you know anything that will help solve my problem please let me know. Thank you!:D
