Corrupt audio driver and blue screens.
    A few days ago out of nowhere i started experiencing a weird audio issue.All dialogues in any video online or on local disc were extremely muffled and basically inaudible while the background music and all sounds were fine,just the dialogue was muffled.I knew it had to be a software issue,i tried everything.I made sure no weird enhancement was active,that the driver was working fine,tried restarting windows audio service but nothing worked.
    Finally while looking under my playback device property levels tab, i changed the balance setting.Initially both left and right were at 100 but weirdly when i moved them,i no longer got muffled sound.Currently i have the left set at 50 and the right at 0 and i'm getting normal sound which is so weird.
    I'm also experiencing weird random BSOD which say VIDEO_DXGKRNL_FATAL_ERROR.I think this is related to driver problems.I tried uninstalling the audio driver but it resulted in the same blue screen.I was able to uninstall the driver in safe mode and re-install it but that did nothing.The driver is Realtek high definition audio 6.0.1.7634.
    What should i do now?
    windows 8.1
    Uninstall your Nvdia geforce drivers and reinstall the latest drivers.
    If the problem still continuous, probably not all drivers and files were removed. Remove the geforce drivers with Display Driver Uninstaller download here Display Driver Uninstaller Download version 15.7.1.0
    Are you sure the display driver is the problem?I was having problems with the audio driver before the blue screens started appearing so shouldn't i uninstall the audio drivers?
    I did try to upgrade the audio drivers, revert to an older version of the Realtek audio driver, completely uninstall the Realtek audio driver, uninstall every audio driver I could find in device manager which included Realtek, Microsoft and NVIDIA audio drivers.This resulted in windows automatically installing the high definition audio driver, but the issue still persists and the blue screen still occour.
    If you installed the generic, basic function, High Definition audio driver and you still have problems, either its a hardware problem with the sound chip (very unlikely) or some other issue rather than the sound chip or driver.
    I would look at the programs that have the problem.
    Well i updated the NVIDIA graphic drivers and so far it's been two days and i haven't seen the BSOD so i guess that's fixed.But the audio issue still persists.It's not so much an issue as an absurdity.Currently the only way i can get sound from the PC is by setting the left speker balance to zero and yet surprisingly the sound comes from both left and right speakers.
Looking for help with my blue screens. in BSOD Crashes and Debugging
As you will be able to see by the minidumps this has been happening for quite a while but i would really like some help with all of this, i have tried to upload to the microsoft forums but they were really no help at all, here is the zip file of the dumps down below, thanks for helping :D 66589
Hi, Having some weird bits happening to my computer all of a sudden when booting up. I did a defrag I did a Check Disk on all the drives, all seem healthy and not in need of repair. So not sure what else to try. The blue screens are basically one of those "Oops, Windows didn't start...
periodic blue screens in BSOD Crashes and Debugging
hi, please excuse me as am new to this. Have been getting intermittent BSOD@s and have not been able to find a solution, was wondering if anyone could take a look for me?
Blue screens in BSOD Crashes and Debugging
So, I am having blue screens and shut off on my laptop with 8.1 and 8 before. I tried everything. Clean installs, BIOS and all drivers update... It gets blue, shuts off and restarts to DOS, and I have to remove the battery and unplug to restart to Windows. Any idea why this happens?
Solved Windows 8 blue screens in BSOD Crashes and Debugging
Dear all, First of all I would like to say that english is not my native language, so apologies. Find attached required document. Thank you in advance. Regards.
Frequent and various blue screens in BSOD Crashes and Debugging
I built my new system in December, and have been experiencing frequent blue screens. For whatever reason, they seem to only happen after startup, usually within five minutes or so. After the restart, though, I've never had a second one - only booting up seems to cause problems. I've...
