Sound stops working for one second or two
    Hello, for a couple of days I started to get thoose sound bugs, it stop working for a second and then the sound continues again.
    This happends when i'm watching a serie or listening to music, whenever I open a new tab on my chrome the sound stops for like a second maybe even a milisecond or so.
    I'm not sure but I think it started when I wanted to clean some stuff from my HDD (C:), (my videos and games), my games was on my (C:) and I uninstalled them and installed them again on my (D:)
    This first was not a problem because it was not a big of a deal, it happened maybe once a hour or so but now it happends more and more often.
    This is starting to get annoying so I decided to finally try and solve this problem.
    More system specs would help us to try and help you. Please fill in the "My System Specs".
    Does this happen only on line? or does it happen playing a music file from the hard drive or from a commercial audio CD?
    How do you connect to the internet? wired or Wi-Fi?
    Okay I just filled it in and yeah I just tried listen to a music file while on chrome and it still stops for like a second or so and then continues, i'm using wired for internet
    EDIT: But it doesn't happens when i'm playing games though
    OK. then its not the sound hardware that is the problem. Something to do with Chrome or just being on line and the audio "buffering".
    You PC sound hardware is Realtek, not "3D".
    Alright thank you for the help, I will try some things out
    Thank you Fireberd, I fixed the problem by your help!!
    It was something about my internet that bugged my sound!
Windows media player works but when i go to places like youtube it works for a little bit then stops .I restart my computer and it seems to work but then their is no sound again.I checked for viruses and got rid of them but it did not help. My volume is on but nothing plays but windows media...
Recently the sound on my Sony Vaio will play initially, but afterwards won't work. It doesn't say it's muted and the little green part that shows sound in the speaker area also doesn't appear when something is playing. I have tried to test the speakers to see if that plays sound but when I do it...
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
Hi In my new HP laptop, with fresh windows 8, sometimes when I'm using sound (eg. listening music in media player and using skype ou browser), sometimes the sound stops. Checking in event viewer, I found appcrash event logs. The sound drivers is updated and windows too. I downgraded the audio...
I recently bought a new computer, an Asus G-Series gaming notebook. Everything has been fine with it, haven't had a problem until now and I was even getting used to Windows 8. I turned it off this morning after playing some games and came back several hours later to play some more. My sound...
Hi All I have a clean install of windows 8.1 and the sound was working but the sound quality was poor/bad so I did some digging around to try and fix the sound quality which didn't work by the way and now my sound randomly stops eg. watching YouTube pause then come back and no sound, restarts...
I am not able to find any event legs showing conflicts, failures anywhere around the time I notice my sound has stopped working, making it that much more difficult to resolve. As of right now I can reboot and sound will come back for an unknown length of time. Sometimes a few days to a few hours....
