Headphone Audio sounds distorted
    Windows 8.1* 64-bit
    Last night I was in a Skype call with my friends and it sounded funny but I didn't notice it.
    (I had earbuds which I gave it away to my relative.)
    I bought some headphones the other day by the way and it came today.
    Before giving away the earbuds I was playing Team Fortress 2 and it sounded weird a little and it was bothering.
    Yet I still continued, after a while I got the headphones and plugged it in the audio jack or what do you call it and its where you plug the headphones or whatever in. So I played TF2 again and the sound was messed up, I could barely hear people and when I watch certain youtube videos it is buzzing very loudly and some I can't hear and some are fine.
    I continuously search for an answer, I found a post on here so I decided do the solution on that forum but it didn't work. I used the Minion's Banana song and if I can't hear the second left minion well and it's sound is distorted or messed up then it's still happening.
    Post I found is here,
    Messed up headphone audio; want to check headphone jack
    I think it is the place where you plug it in, somethings wrong with it so any solutions?
    Windows 8.1* 64-bit
    Anyone? :9
    I assume, from your posts, that the internal speakers work OK?
    If the headphone out has NEVER worked correctly and the PC is still in warranty, best option is to call HP as only HP can get it corrected under warranty.
    Windows 8.1* 64-bit
    The audio is messed up when it's plugged in, yet it's perfectly fine unplugged
    That confirms what I asked, about "internal speakers work OK".
    Assuming the headsets you have used are known good headsets, it points to a possible hardware problem. As I previously noted, if its still in warranty, call HP (or whoever you have the warranty with) as only they can get it corrected under warranty,
    Windows 8.1* 64-bit
    Ok, thanks for your help, I'll call HP whenever I have the time.
    Windows 8.1* 64-bit
    Apparently the warranty is gone, I've had this for a long time. What should I do?!
Mu audio playback all of a sudden sounds like its' under water. Is there a quick, east fix??
Hey all, I've been using a Windows 8.1 HP Envy laptop for quite some time with no problems. It used to have very strong headphone output, and I could hear it just fine even at 2-3% volume. However, a few days ago I made the mistake of going into the preinstalled Beats Audio manager and...
Hi everyone, Lately my computer has been distorting sounds and been going slower than it used to. When I restart the computer, the amount of distortions/small sizzling sounds is at a minimum, but it increases as I continue to use the computer. I googled how to fix this and one of the ...
I have a PC built from an Asus P5B-WiFi Delux motherboard running Windows 8 Pro with Classic Shell which has an Realtek HD audio on board sound device. I also have a Creative X-Fi Gamer sound card installed. All of these were installed and working correctly. One time I unplugged my speakers...
