All sound fades until loud sound is played USB headset.
    Windows 8.1 64bit
    All sound from the PC fades out over the course of ~2 seconds only to instantly return when a new (loudish) sound is made. It almost feels as if the headset is raising its baseline of noise after a bit and things the normal sounds are just nothing until a loud sound comes in and makes it realize there is still noise to be played. Best way to describe it is having poor thresholds set to a VoIP voice detection, you make a loud noise and it will kick on and detect lower noise for a bit before shutting down again.
    Headset is a Skullcandy PLYR2 Wireless Headset USB plugged directly into MoBo
    I have not had this issue happen when using my monitor's speakers (HDMI into GPU)
    There is no sound card on this PC, and I've not been able to find any sort of software to control the audio processor outside of the windows playback enhancements.
    Windows Communications volume attenuation is set to do nothing, VoIP programs are off as well so as to rule out those. No enhancements are on in windows playback enhancements.
    Gigabyte B85M-DS3H
    16 GB 1600 DDR3 1600
    Seagate Barracuda ST1000DM003 1TB
    EVGA 01G-P4-2753-KR Nvidia GeForce GTC 750
    Intel i3-4160 3.60GHz
    Windows 8.1 64bit
    When you use a USB connected headphone (wired or wireless) you do not use the PC's sound card, The USB system does the conversion from digital to analog audio. Thus the problem is somewhere in the USB headset system.
    Windows 8.1 64bit
    It seems that turning on loudness equalization has "fixed" the issue, I had the headset turned to max volume and had all my sounds down so far the headset seemed to be interpreting the low signals as no signal. So now i just have to deal with not being able to have control over volume if I don't want it turning itself off. So I guess solved. Thanks for the help Fireberd.
Hello! I just bought a brand new headset and the volume is really loud on my computer... I set the volume to 1 and everything but youtube is loud as heck. The inline volume control just adjusts the windows volume so that does not help. Any programs that can make the volume like 0.1 % ?
Hello! I am trying to do some recordings of video games for my friends videos but I am having issues with recording desktop sounds (in other words the game itself) anything I do doesn't work. What I am wanting to do is have stereo mix as my default recording device and have my headset as the...
Bluetooth Headset Sound Loop in Drivers & Hardware
Hello guys i have a Bluetooth Headset (Xtreme XM-1200) i have connected it with my Laptop Toshiba C660-A048 but it got sound loop after 5munite when i play music, what to do ?
Greetins all, Is there a way for me to decide where what sound is played? I got it setup now that all communication is played though headset but all other sounds are sent out though the HDMI cable to my sound system. I know some games and application allow me to select under options...
No sound using 360 headset in Sound & Audio
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
Headset sound quality in Sound & Audio
Hi! I would like to ask if anyone knows why is it that headset sound quality is defaulted to the lowest telephone quality, and the dropdown menu to change it is inactive? In Win7 I could change it to better (or it was deafult the best, I don't remember), but now the sound is just abysmal. I used...
