Dell Inspiron 3543 Realtek ALC3234 Audio problem
    Hello all,
    I have dell inspiron 3543 and it has realtek alc3234 chip.
    when I'm installing realtek/dell oem drivers, the sound is going really horrible and loud/low automaticly.
    headphones are also not sounding good..
    without drivers sound is ok, but not much advancements. whaat can be the cause? I've installed latest drivers, performed all troubleshooting steps, but wasted
    Please provide a screen shot of the Device Manager, Sounds section. It sounds like there is some type of conflict.
    Hi bro,
    screenshot of what? of audio divice properties?
    Screenshots added(I'm blind so I'm not sure that screenshots are correct or not, but I've tried my best, my screen reading software doesn't recognizes images)
    Got it. The Bluetooth device could be causing some of the problems. Has it ever worked correctly?
    I don't use bluetooth device, should I disable it?
    virtual device, but no effect. same as before
    I've disabled both bluetooth handsfree device and NVIDIA
    NVIDIA is only for HDMI audio.
    Has this ever worked correctly in Win 8.1?
    ked ever in windows 8.1 fine. I'm tinking to install windows 7 for trying it out, but I can't use win7 always. and I'm really annoyed by this problem
    no, it has not wor
    I don't see anything apparent that would cause it to act as you say. A factory reinstall may take care of it. F8 at power on will access the Dell PC Restore and restore it to the original factory condition. However, that will delete user data so back that up first.
    Dell has diagnostics listed on their support site. That is another option.
    http://www.dell.com/support/home/us/...iagnose?rvps=y
Page 1 of 2 12 LastLast
I am currently using windows 8.1 on my Dell Inspiron N5010. While the wireless module is working perfectly, the Ethernet port gets frequently disconnected due to unknown reasons. To make it function again, I need to reinstall its drivers every time. Can anyone figure out the cause behind this and...
Hi, I have a problem with my front audio jack. The cause of this problem may or may not be the DAW reaper. I set my front headphone jack on my laptop as reapers input and the speakers on the laptop as its output. This did not work so I uninstalled the program. I tried to use my headphones but there...
I Made a bootable usb drive...using ROFUS..(i.e, UEFi supported):thumb: But this Laptop Fails to boot from usb drive... It Just Boots to Installed Os.. Please Help me to Resolve this Issue.. i Want to Install Windows 8..ASAP :(:confused: :cry:
I unplugged my pc and moved it into the other room. Now my sound blaster recon 3d pcie soundcard isn't working at all. I took it out, put it back in (same slot and even tired a different slot), Installed the Windows 8 driver for it, restarted my pc and it's not there. No where.
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
Hello All, I thought I would post an interesting Installation of Windows I did on my Dads 2006 Dell Inspiron 6000. I am posting it in the Drivers section because Dell never made a Audio driver for the Inspiron 6000 past Windows XP. I had to do this trick for Widows 7, so I thought I would try...
