Dell Inspiron 3543 Realtek ALC3234 Audio problem
  1. #11
    I don't see anything apparent that would cause it to act as you say. A factory reinstall may take care of it. F8 at power on will access the Dell PC Restore and restore it to the original factory condition. However, that will delete user data so back that up first.
    Dell has diagnostics listed on their support site. That is another option.
    Product Support | Dell US
    . aparently I suspect that this particular chip may be faulty, actually I've noware seen REALTEK ALC3234, but this laptop has this unknown chip
    I'll try fresh OS install
  2. #12
    'll install win 10 today and check
    I
Page 2 of 2 FirstFirst 12
I am currently using windows 8.1 on my Dell Inspiron N5010. While the wireless module is working perfectly, the Ethernet port gets frequently disconnected due to unknown reasons. To make it function again, I need to reinstall its drivers every time. Can anyone figure out the cause behind this and...
Hi, I have a problem with my front audio jack. The cause of this problem may or may not be the DAW reaper. I set my front headphone jack on my laptop as reapers input and the speakers on the laptop as its output. This did not work so I uninstalled the program. I tried to use my headphones but there...
I Made a bootable usb drive...using ROFUS..(i.e, UEFi supported):thumb: But this Laptop Fails to boot from usb drive... It Just Boots to Installed Os.. Please Help me to Resolve this Issue.. i Want to Install Windows 8..ASAP :(:confused: :cry:
I unplugged my pc and moved it into the other room. Now my sound blaster recon 3d pcie soundcard isn't working at all. I took it out, put it back in (same slot and even tired a different slot), Installed the Windows 8 driver for it, restarted my pc and it's not there. No where.
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
Hello All, I thought I would post an interesting Installation of Windows I did on my Dads 2006 Dell Inspiron 6000. I am posting it in the Drivers section because Dell never made a Audio driver for the Inspiron 6000 past Windows XP. I had to do this trick for Widows 7, so I thought I would try...
