Sound plays through headphones and built-in speakers
    When I plug in my headphones, the sound still plays through the speakers! I can hear the sound in the headphones though. I have updated the drivers and set the communication headphones to default but it still didn't work... Please I need help immediately!
    I have a HP Pavilion AR5B125 15.6" Laptop with IDT Drivers
    More Info:
    Some sound software has options to mute or not mute the speakers when a headset is plugged in. I don't have IDT so I can't say if or how its managed in IDT. Realtek has an option it its control panel for this.
    My sound software does but there is no option for muting the speaker...
    Normally, Stereo Mix is set as the default recording device. Then whatever input device it is used. Don't have to set a specific device. However, I don't think that is your problem.
    Has it always acted this way or is this a recent problem?
I have looked for hours over the Internet for my problem but I have not found a solution. Sound plays through both the headphones and speakers when I have the headphones plugged in. I want the audio to play only through the headphones when I have them plugged in. When I check my playback devices:...
So Recently I got a new computer its an Acer. It only has one jack for headphones and microphones and usually when I plug one in it works fine and asks me to clarify which I'd like to use. I switch between headphones and microphone a lot so its a very useful tool for me. Though recently when I plug...
Windows 8.1 64-bit Realtek High Definition Audio Motherboard: B85-G41 PC Mate(MS-7850) Speakers: Logitech X-530 The set includes 4 speakers ( two front and two back), Center, and Subwoofer. I'm not using the two back speakers. In the RealTek Audio manager's sound test, I hear sound...
Speakers and Headphones? in Sound & Audio
Hey, I was trying to get Skype to play through my headphones and Spotify to play through my speakers. I have tried everything, using realtek manager to set the headphones as "Headphones" and my speakers as "Front Speaker Out". I downloaded the trial CheVolume, which looks pretty useful however...
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
