when i plug headphones sound volume drops
    windows 8.1
    So here´s my problem. WHen i use my computer speakers the green bar on the volume settings goes to 100%. When i plug any headphones the green bar only goes pretty much up to 50 or 60% up. I´ve tried windows media player, vlc, games, youtube it happens everywhere.
    Can anyone help me?
    More information is needed. Please fill in the "My System Specs" as it helps us to help you. Also what type of headphone are you using? A USB or standard analog?
    Harrisonburg, Va.
    Click on your speakers & set the volumn to 100%-
    windows 8.1
    Thank you for your answers but i solved the problema in audio wizard. I turned off maxxvolume and maxx leveler
Hi I have a dell windows 8.1. Everything has been fine for a long time and now... no sound. I must admit to never really understanding how sound works on my laptop. After some fiddling around I managed to get some sound - but only when speakers are plugged into the headphone socket. Now my PC...
i have Asus X450JF with windows 8.1 pro 64bit. everytime i turn on the laptop, and i plug the HDMI cable, there is no sound on my TV even in the playback devices. i unplug and replug the cable then the sound appeared on my TV. i already tried many drivers (from intel and the asus manufactured...
Ok, so been using a dell XPS 13 2015 edition for about a month now. An hour ago I tried playing some music and it wasn't playing. This led me to clicking the volume icon in the system tray and the following popped up: 64068. Sometimes the "looking for errors" screen turns up instead, and it find...
So I've decided to record me covering a song today, but about 30 seconds withing the recording the sound quality just drops and sounds like something was placed over the mic giving it a muddy sound. Any way to fix this problem? Thanks in advance! c:
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Sound Drops randomly in Sound & Audio
I had only had this laptop (Lenovo IdeaPad n585) for 2 weeks and this problem showed up in the last 3 days. When running a something with sound (usually chrome, but recently it happened during a game) the sound specifically for that program would drop a random amount at a random time. This would...
