sound only works with headphones - no control over volume
    windows 8.1
    Hi
    I have a dell windows 8.1. Everything has been fine for a long time and now... no sound. I must admit to never really understanding how sound works on my laptop. After some fiddling around I managed to get some sound - but only when speakers are plugged into the headphone socket. Now my PC controls make no difference to the volume. I think the ss below suggests that I want the sound to go through the 'speakers headphones' but the sound level meter says its using the communications headphones.
    This is what I have for my sound card.
    The same happens when I stream audio - only works if headphones connected and no control over the column from pc.
    Lastly, when I right click on the top one and click test it says 'failed to play test tone'
    Can anyone help please?
    Many thanks
    E
    The first thing I see is you do not have the correct sound driver. You only have the generic, basic function, Windows installed High Definition Audio Codec (Driver).
    First step is to install the correct hardware sound driver. Not enough system spec's provided so I can't research what you need. If its a factory built PC, go to the PC vendor and download the Win 8.1 driver. If its custom built, go to the motherboard vendor for the driver.
    windows 8.1
    Hi - and thanks for your reply. I went to the dell site and ran a tool that told me that there was a new driver. This I installed and hey presto - all is well.
    Thanks for the pointer
    Edward
I have an issue where I can only hear sounds when I constantly change my volume on the slider. If I don't change my volume, then my audio fades away in about two seconds. Can someone help me fix this problem? Additional information: I have a Logitech USB Headset H390, Running Windows 8.1
First up I am a not a too computer smart 70yr old. For some unknown reason the volume control icon has disappeared from my task bar (when I move my mouse hard right and it shows battery state. internet access, language, volume etc.) which I use continuously. I have been to every avenue I can think...
Greetings! I'm having a little problem here which I wasn't quite able to solve using the official Creative Support. First a little explanation: Before installing my new Sound Blaster ZxR I had to temporarily use the Onboard Sound of my Asus Rampage IV Black Edition because of a SLI Water...
Make Volume Control On Top in Sound & Audio
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio...
Volume Control in Sound & Audio
Hi Guys, anyone know if its possible to get an on screen volume control when you are playing music. At the moment I can only see how to start and stop music from playing. I can turn the volume up and down via my keyboard but would like to do it on screen via my mouse. If I drop to my old...
