Sound keeps resetting every time an application plays sth.
    Windows 8.1 Enterprise 64-bit
    Hi everyone, this problem is driving me insane:
    I'm on Windows 8 (but I've also had it on my previous PC with Windows 7), 64-Bit.
    My soundcard is Realtek HD.
    Every time an application plays sound (e.g. youtube, a computer game, mp3 player) for the first time after it's loaded up, the sound is massively loud.
    However, if I go to the volume control and put the volume down a notch and then back to the original setting, it is back to normal. So what happens is that for some reason the sound goes super loud even though the windows setting is on average, and only modifying the windows setting makes it use that setting again.
    Now, things that I've already tried:
    * Googled this problem like crazy, but every single solution that I've found has always been:
    * Sound -> Communications -> Do nothing. My setting has always been on Do Nothing, but I've tried the other settings as well, just for fun. Same issue. So for now it's back on do nothing.
    * De-activated the Realtek HD Audio Manager in case it was interfering. No success.
    * Looked at the Dell and NVidia audio settings, but they are all very minimalistic and none of the settings there look like they would do anything.
    * Installed the latest Realtek HD drivers and now my audio is all tinny and crap, it sounds like through a phone, wtf! Phew, fixed that by completely kicking the realtek drivers and just using the default windows ones.
    Please help my poor damaged eardrums!
    Thanks!
    The Realtek drivers are not the problem, unless this is an old PC that has been upgraded. What is the actual Dell Model number? such as OptiPlex 360, etc.
    Having the Stereo Mix (may be called System Mixer) as the Default Recording Device may help this.
    The default Windows installed High Definition Audio Driver (Codec) is only a generic, basic function driver. I don't think it has the Stereo Mix.
    I have a Dell Precision Tower 5810.
    And you're right, the stereo mix doesn't show up with the default drivers (I have a Volume mixer, but that's not what you mean I think).
    But you know what, I think the volume jump might actually, finally, be gone. I'm gonna have to observe over the next couple of days and report back, but I think it might have been the drivers after all.
    Dell doesn't list a 5810. The list shows a T3610, T5610 and T7610?
    Weird. It's definitely 5810.
    Either way, it hasn't been happening since I nuked the drivers, so I'm happy
    Thanks!
    Edit: Just as an update, it's been over two weeks now and I've not had the problem again. Driver nuke =
I have looked for hours over the Internet for my problem but I have not found a solution. Sound plays through both the headphones and speakers when I have the headphones plugged in. I want the audio to play only through the headphones when I have them plugged in. When I check my playback devices:...
Windows 8.1 64-bit Realtek High Definition Audio Motherboard: B85-G41 PC Mate(MS-7850) Speakers: Logitech X-530 The set includes 4 speakers ( two front and two back), Center, and Subwoofer. I'm not using the two back speakers. In the RealTek Audio manager's sound test, I hear sound...
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Recently the sound on my Sony Vaio will play initially, but afterwards won't work. It doesn't say it's muted and the little green part that shows sound in the speaker area also doesn't appear when something is playing. I have tried to test the speakers to see if that plays sound but when I do it...
Hello everyone,after using Windows 7 Ultimate on my laptop for almost 2 years I decided to upgrade to Windows 8. The first day it was working fine,no problems at all. The other day I disconnected my USB mouse and it would keep on playing the disconnect sound, however, I solved that issue. Recently...
