No sound from speakers
    Hello,
    I have an issue with the sound in my Lenovo Z500 laptop, running Windows 8.1.
    It has been playing sounds well until a couple of days ago. My son plugged in Sony headphones into the audio jack a couple of times and then the problem sprang up. Even after taking the headphones out of the audio jack, the laptop thinks that the headphones are connected and the sound does not come out from the inbuilt speakers at all!
    When I restart the computer (with no headphones connected), I see a message at the bottom right corner of the screen "You just plugged a device into the audio jack"!
    I even resorted to reinstalling the latest audio driver... no luck still
    Can someone help me please.
    Thank you.
    From your description, it looks like the headphone jack is damaged. Some laptops have a separate "daughter" board that contains the I/O jacks and can be replaced. On others it requires replacing the complete motherboard. Check with Lenovo on your particular model.
    I have a Z510 laptop, but do not have any documentation, as it may be similar.
    Thank you, fireberd.
    Yes, I suspect it is a hardware fault. I restored the OS/laptop using the factory image and still no luck. So I'm pretty confident it is a hardware fault.
    Thanks for your help!
this is my latencyMon screens 54926 54927 please give me steps what should i do
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
Ghost sound/speakers.. in Sound & Audio
Hey guys So this is a weird one... I have a Xonar D2 sound card, and the Xonar D2 Audio Centre, all sound thru my speakers and headphones fine. All music, games, skype are heard and picked up on the D2 Audio Centre just fine. HOWEVER When I open the Volume mixer, almost every program I have...
Well this has gone for a few weeks and I had my laptop for about a year now. The problem is after watching 3-4 videos, the sound will not work on the next file. I tried restarting and it worked! But after another 3-4 videos, there was no sound again. Another thing is when I open a music file, it...
