Sound plays through both headphones and speakers
    Microsoft Windows 8.1/Corporation 64 bit
    I have looked for hours over the Internet for my problem but I have not found a solution. Sound plays through both the headphones and speakers when I have the headphones plugged in. I want the audio to play only through the headphones when I have them plugged in. When I check my playback devices: http://i.imgur.com/WUhT1UF.png when the headphones are plugged in or not. When I disable the device no audio comes from the laptop. It says my Realtek HD Audio is up to date http://i.imgur.com/cSDUQFv.png. I am using Windows 8.1, 64-bit. Is there anyway to get the sound to only play through the headphones when I have them plugged in.
    The Realtek HD Audio Manager, has options for either muting the speakers when a headset is plugged in or to not mute them.
    What window is that? How do you get there? Searching "Device advanced settings" on my computer doesn't bring up anything and neither does "Realtek HD Audio Manager
    The Realtek HD Audio Manager is on most PC's. There are a very few that came from PC manufactures with it disabled. On those, upgrading using the drivers direct from Realtek, usually adds it. Realtek
    The Realtek HD Audio Manager is located in the Control Panel/Hardware and Sound. My Win 8.1 has been upgraded to Win 10 so I can't point you directly on how to access it.
    This is what the Realtek HD Audio Manager looks like. The Device Advance Settings is where you access the speaker controls.
    When I access "Hardware and Sound" on my Control Panel, I get this: http://i.imgur.com/TwMFHwG.png
    Installing the drivers from Realtek MAY add the control panel. Realtek Install the correct 8.1 64 bit High Definition Codec (drivers)
    BTW, here is how to post screen shots on this forum, rather than linking to another site.
    I installed the 8.1 64 bit High Definition Codec but it still did not show up in my control panel
    I don't know of another way to manage how the speakers and headphones act. You could contact HP and see if they know. I know Sony disables that function on some of their laptops but have not heard of that being disabled on a HP.
    Ok, thanks anyways.
So Recently I got a new computer its an Acer. It only has one jack for headphones and microphones and usually when I plug one in it works fine and asks me to clarify which I'd like to use. I switch between headphones and microphone a lot so its a very useful tool for me. Though recently when I plug...
Windows 8.1 64-bit Realtek High Definition Audio Motherboard: B85-G41 PC Mate(MS-7850) Speakers: Logitech X-530 The set includes 4 speakers ( two front and two back), Center, and Subwoofer. I'm not using the two back speakers. In the RealTek Audio manager's sound test, I hear sound...
Speakers and Headphones? in Sound & Audio
Hey, I was trying to get Skype to play through my headphones and Spotify to play through my speakers. I have tried everything, using realtek manager to set the headphones as "Headphones" and my speakers as "Front Speaker Out". I downloaded the trial CheVolume, which looks pretty useful however...
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
I bought the plantronics .Audio 335 studio headphones, but when I plugged them in, it screwed up my sound. My compute'rs sound is now playing through both the headphones AND the laptop speakers. After unplugging it and trying again a couple times, I gave up and decided to just use my old...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
