Headphone mic not detected
    Hello,
    I just realised that all this time on Skype and FPS games, I am using my built-in mic and not my headphone mic. My headphone mic is working perfectly on iPhone, iPod and other mobile devices but on my laptop the mic is somehow not detected. Please help me, how do I enable my headphone mic? Headphone is working fine, audio is fine but the mic is not in used, only using the built-in mic on my laptop.
    I've done some voice recording and I notice it is using my built-in mic and not the headphone mic. It is already plugged in with combined jack. Using splitter cable also not working. Screenshot shows my recording devices, if that matters.
    Note : I also test with my other headphones that has mic and same thing, mic not detected on my laptop, still use built-in mic.
    Depending on what type of jack(s) you have on the Laptop, the iPhone type headphone/jack connector will not work. If this is the case you need an adapter.
    Iphone type plug
    Standard Stereo Plug used by most PC's.
    Never mind, it finally works now. After several google searching, I figured my Realtek HD Audio Manager is out dated. I downloaded the one provided here in this forum, and after installing it, it now detects the mic. My recording devices now shows the right panel jack on the information, thanks though.
    Cool. Thanks for the update. Please mark this thread Solved.
Windows 8.1 Headphone Jack in Sound & Audio
I have a Dell Inspiron 15 Laptop ( Dell Inspiron 15, 15.6 HD Backlit Display, Intel Celeron Dual Core, N2830 Processor, 4GB Memory, 500GB Hard Drive, Windows 8.1, No Optical Drive: Amazon.co.uk: Computers & Accessories ), and my problem is that when i talk to my friends over 'Skype' or 'Teamspeak'...
Windows 8 Headphone Jack in Sound & Audio
This seems to be a pretty common problem. I'm working on my friends computer, because his headphone jack isn't working. He has an Acer Aspire M, with a third-gen i5, 6GB DDR3, Windows 8 64bit, and a Realtek card. He had been using headphones in the side jack, and they were working fine, but...
Mic through headphone in Sound & Audio
Hi. I am having a VERY frustrating issue. I bought a Turtle Beach Earforce PX-21. (link to headset here). I use the headset for chat using teamspeak 3 while playing games. (link to teamspeak here). My motherboard is a ASUS SABERTOOTH 990FX R2.0 (link to motherboard here). The problem is pretty...
Solved no sound in headphone in General Support
I am using window 8 (64 bits) Speakers are working fine but there is no sound in headphone
Headphone Jack Not Working in Sound & Audio
I updated to Windows 8 today, and everything seemed to be going well until I tried playing music through my headphones. They worked fine on my iPhone, but once I plugged them into my laptop, no sound came out. Pictures: http://i.imgur.com/QsxifqG.png http://i.imgur.com/eZsVKBe.png I ran...
Hi...in my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug...
