Microphone inputs do not work on back or front panel
    Windows 8.1 64 bit
    Yesterday everything was fine. Today I woke up and I had this issue.
    The headset I use comes with 2 3.5mm cables that need to be put into both the audio output jack and the microphone input jack. The audio output works fine, however, the microphone input jack does not pick up my voice or anything.
    These are my volume settings:
    Click image for larger versionClick image for larger version
    Everything looks fine there and everything is plugged in fine. I have the latest RealTek drivers installed and my motherboard is the ASUS Z97-K. I checked the BIOS settings and everything seemed fine, it was set on HD audio and was the same before this issue randomly occurred.
    Would really like help solving this as it is so frustrating not being able to use my mic. Also, I have tested the mic on other computers and it works fine so clearly something is wrong either with the hardware or software on my PC. Also, this PC is quite new maybe a month so far. Also, I have windows 8.1 64 bit installed.
    Thank you in advance.
    Did you do the "Refresh" as I suggested on the Win 7 forum?
    Windows 8.1 64 bit
    After I restored should I reinstall the realtek drivers or should I just use normal windows drivers?
    Also should I download from here? Realtek
    or here http://www.asus.com/support/Download...rV4y53ywKS/41/
    Just do the Uninstall, in the Device manager, but DO NOT uninstall the drivers. Then restart the PC and when Windows starts it will detect and reinstall the sound, using the already installed Realtek drivers.
    Windows 8.1 64 bit
    Those were the two I uninstalled and now I have restarted my pc, however, the problem is still there.
    If you're wondering why I don't have the realtek drivers installed it is due to me restoring at a point where I didn't have them installed. I only actually had the realtek drivers after the problem arose and I tried to fix it.
    The Realtek sound driver is the one to be uninstalled, not what you show.
    Its listed under Sound Video and Game Controllers.
    See my listing. It is from Win 7, but Win 8.1 is the same.
    Windows 8.1 64 bit
    Ah, okay. Well it doesn't seem like I have those drivers.
    Like I said earlier I do not have the Realtek drivers installed due to the restore point I used and was wondering where to download them from their website or my motherboard's website. The images in the original post are outdated sorry.
    OK. You don't have Realtek drivers installed. You only have the generic, basic function, Windows installed High Definition Audio Device.
    Download and install the Realtek drivers.
    Here is the link to the ASUS downloads.
    https://www.asus.com/Motherboards/Z9...Desk_Download/
    Windows 8.1 64 bit
    I downloaded & installed this
    and here it is in device manager
    Also, thank you for being patient with me
    Is everything working OK again? Or are there still problems?
Page 1 of 3 123 LastLast
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Hi, I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card. Not sure what other info will be needed. ...
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
