Microphone inputs do not work on back or front panel
  1. #21
    There is something missing from your report.
    First thing is to try a different microphone. that is the only thing left and the only common point.
  2. #22
    Windows 8.1 64 bit
    Okay I'm back. I used a G930 Logitech headset to test and it works...halelujah. So usb works but mic jacks do not. Any advice?
  3. #23
    That points to the sound hardware as the problem. If USB headset works OK, its taking the digital audio (same as what the sound card receives) and converting it in the headset or vice versa taking the analog mic and converting it to digital for the PC.
  4. #24
    Windows 8.1 64 bit
    So this is a motherboard issue, correct?
  5. #25
    Yes, a motherboard problem.
  6. #26
    Windows 8.1 64 bit
    Urgh.....well, looks like I'm going to be taking this one back and getting a replacement, was hoping this wouldn't be the case...
    Also, I wanted to ask if you would know why the small USB 'soundcard' did not work with my headset. I plugged it in, it comes up as a USB device, but I cannot use the mic, however, the audio output works. I would assume since the USB headset I used earlier works, that this would work as well due to the ports not being used...
Page 3 of 3 FirstFirst 123
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Hi, I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card. Not sure what other info will be needed. ...
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
