*Urgent* No noise at all, even after complete reset
    I have a windows 8 laptop that is making no noise whatsoever. Yesterday morning, I go to youtube to do my normal everyday routine of watching videos and video makes no noise. Shrugging it off, I just do a standard turn off turn back on that usually does the trick. I try again and nothing. I go on different websites; nothing. Being pretty tech savvy, I searched for a few hours to no avail so I just preformed a TOTAL reset. Yes, I lost all files and fingers crossed, hoped it would work. Still nothing. I am so frustrated I have no idea what to do.
    Heres a screen shot of my device manager.
    (Yes, my volume is not on mute and is turnt up to 100%)
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    According to the screen shot everything appears to be normal but what I usually do is shut the computer down then pull the power cord from the back of it, wait about half a minuter then try again. Had you checked that the speakers are plugged into the correct port, usually light green? Have you checked in Control Panel, Sound for the correct output setting? Have you tried a different set of speakers or a headset in the same port?
    Quote Originally Posted by Berton View Post
    I have a laptop.
    Forever West
    But nearly all Notebooks/Laptops have a port for external speakers/headphones and a port for a microphone. Also note that in addition to the Windows volume control/s there also is a hardware control or two using the keyboard or dedicated buttons for controlling.
Whenever I start playing a game, no matter what game, I get weird buzzing feedback from my headphones or speakers, depends on what I use when I play. They both make the same noise at the same places (certain menus, while in-game, etc). I also can't make my built in mic on my earphones to work. I...
Hey guys, i found this info form a website on how to completely reset your network.. take a look at this and can someone update it to comply with windows 8.1 64bit? -what is missing for windows 8.1 64bit to totally reset your network.. this probably should be a sticky at some point too as...
Hey guys, didn't want to double post so here is my question but I really like this "general" forum so I posted it here too.. -quick question about Completely resetting your network in windows 8.1 please have a quick look below.. ...
Solved strange noise from PC in Drivers & Hardware
About 2 days ago i opened PC case to do my regular maintenance of dusting inside. Usually use Compressed air. Have 2 case fans (1) 92mm (1) 80mm plus the CPU Cooler fan, my Graphics card has dual fans. Just other day and this only happens when i am booting the PC, i hear what sounds like and...
Bad noise on quite new laptop. in Drivers & Hardware
Hi, I hope somebody can give me an opinion from his experience. This laptop is 4 months old, Asus X501A. I had to return another one to Amazon because it made some bad clicking noises and the hard disk was faulty as Hard Disk Sentinel said it was with 68% health new. So, this laptop model might...
Urgent Help in General Support
Hey, Ive recently found out that im not admin of my own computer, i cant even access some of my very own files and cant change important settings such as windows automatic update and download some files, ive tried everything for example hidden admin and much more, i also cant even PRESS A BUTTON...
HDD locking noise? in Drivers & Hardware
I've recently just updated my BIOS on my asus laptop to fix my "ACPI.sys" problem but now, whenever I plug an external USB drive in, or do a hybrid shutdown my hard drive makes 2 loud-ish locking kinda noise (similar to when I turn on my laptop), i'm guessing its the HDD head parking... Should I be...
