No Surround Sound
    No Surround Sound
    I think the problem started after i upgraded the realtek drivers but i cant be sure. The surround sound i have on my system just stopped working. Currently, i only have the stereo sound. Also my microphone isnt working at all.
    Computer Model: MSI GT60 2OC
    8gb ram
    Intel i7
    480ssd and 1tb hdd
    Latest realtek hd audio driver
    I have tried reinstalling my whole system to fix it but it still didnt work.
    If reinstalling the "whole system" did not fix it, I would suspect something other than the Realtek drivers.
    What speaker system do you have? 2.1, 5.1 or 7.1? Is the speaker type set correctly in the Sound Panel, Playback section for the type of speaker system you have?
    In the Sound Panel/Recording section, Stereo Mix should be set as default recording device.
    It should be 7.1. As for the reset, i just used the reset function from windows and provided the windows file. I'm not sure if it removes the old drivers since right now, there's 2 realtek hd audio drivers and microphone. I've tried to configure the 7.1 surround in the options but the sound doesn't play when i test it.
    Go to the Device Manager, Sound section and uninstall all the Sound Devices but DO NOT uninstall any driver. Then restart the PC and when Windows starts it will detect and reinstall the Realtek (and HDMI audio if you have that).
    I have done that about 9 times now. Tried both the stock and latest driver from Realtek. Is there a way to completely remove all audio drivers? When i uninstall it, the drivers auto install from somewhere after i restart my computer.
    Click image for larger version Click image for larger version
    This is what happens when i uninstall the drivers and restart my computer.
    I even went as far as uninstalling the hidden/old drivers. But it still doesn't work.
    The High Definition Audio Device drivers are the generic, basic function, Windows installed drivers. I don't know if they offer 5.1 and/or 7.1.
    Have you tried the Realtek driver on the Realtek site? www.realtek.com
    The thing is, it worked before. I'm just not sure when or what caused it to stop working. The laptop i have is the GT60 2OC from MSI, and it came with Sound Blaster Cinema. Along with my laptop is 2 stereo speaks right under the display on both sides, 2 speakers in the front, and 1 sub woofer on the back. Here's the link for the GT60 2OC.
    Check the SoundBlaster Cinema as that may be where the surround is generated/configured.
    I have tried that too. However, there is still no sound coming out from the front speakers or the sub woofer.
    MSI GT60 2OC Specs
    This is the audio it's suppose to have:
    2W X2 HD 2 Speakers, 1 subwoofer
    The other specs aren't the same but that's almost the same model i have. [besides the ram,storage, and cd drive]
No Surround Sound
Hello all. I bought the Z506 today for 55 for my PC but for some reason 2 of the speakers and the surround sound system with the 2 speakers buillt in do not work. I have them all connected up correctly on my Gaming PC. Is the black and orange socket thing on the end of the black wire for...
Surround sound systems. in Sound & Audio
I been randomly planning out my eventual upgrade to surround, I have an odd setup with 3 20$ 2.1 systems for center and front, wired the side to go to the front as well. But I have noticed the sound volume is bascily halved when you change the system from stereo to surround....whose the moron that...
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Streaming to surround sound in Sound & Audio
Hi guys, I want to stream my music and videos from my laptop to my smart tv via Wi-Fi so I can listen through my surround sound system. I cannot seem to do it through the music and video apps in win 8.1 Anyone know how to set the apps to stream to DLNA devices? Thanks
I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price. So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable -...
I have tried for some time now to get my surround sound to work on my Packard Bell Ixtreme X8540 since upgrading to Windows 8 via Microsoft's upgrade tool. When I had Vista installed, there was an icon on the bottom task bar which would take me to a control centre for the audio which gave the...
