Turn off notification sound for specific apps...?
    Is there no way in W8.1 to turn off notification sounds for specific apps with annoying notification beeps (in my case FB)?
    Everywhere I look, including in this forum, shows me how to turn off notification sound for ALL apps, but I just want to turn it off for SOME apps, those that beep annoyingly and too often. It seems to me that the apps rely on W8.1 for notification sound management, but nowhere do I seem able to turn off the sound for specific apps. Is it me or is it W8.1...?
    Hello OppfinnarJocke,
    The notification sound is a global setting that can only be completely turned on or off.
    If you like, you could turn off showing toast notifications for individual apps though that would effectively no longer have a notification sound afterwards since there will be notification.
    App Toast Notifications - Turn On or Off in Windows 8
    Ok, thanks for confirming this flaw. It is a very strange oversight, I must say; such an obviously useful feature (to me at least) and none of the W8 developers thought about it? Looking forward to W10...
    Thanks.
    Yeah, it would be nice to turn on/off or change the notification sound for apps like in Windows Phone.
System specs (TL;DR Below) Hi, first post here, 1 week ago my laptop started to freeze on some games (osu! and Hearthstone). I can barely play 10-60 minutes before my screen freezes while having a buzzing Sound-loop (I have to force restart to make my laptop work again). (This always scares...
How to Turn On or Off Bluetooth Notification Area Icon in Windows There are many different types of Bluetooth enabled devices you can add to your PC, such as mobile phones, wireless headsets, and wireless mouse devices and keyboards. After you've paired (connected) a Bluetooth enabled...
Email notification sound in Sound & Audio
I`ve read all of the tutorials on setting an email sound for Outlook 2007 but to no avail. All of the notification settings are on and in control panel/sounds/ i set to both Desktop mail notification and new mail notification but still not getting a sound for new emails arriving. Could you help...
Some setting must have changed. Or maybe it was the 8 to 8.1 update. I use to get a notification at the upper right when I turned on an external HD, or inserted an SD card. I could click on it, and it gave me the opportunity to open it in explorer. Now I don't get the notification. The...
How to Turn Notifications On or Off from Specific Apps in Windows 8 and 8.1 Toast notifications in Windows 8 and 8.1 are balloon type notifications that appear as a themed bar in the upper right corner of your main display to allow an app to communicate with you whether your are in another app,...
Is it possible to change the alert sound?
How to Turn Play App Notification Sounds On or Off in Windows 8 and 8.1 This tutorial will show you how to turn on or off to play notification sounds for Store apps in your user account in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. To Turn On or Off Play App Notification Sounds...
