My microphone is making loud noises.
    64 bit
    here you can hear it https://www.youtube.com/watch?v=1tcf...ature=youtu.be
    Its not because of my headset i changed it 2 times
    anyone can help?
    I hear nothing on your youtube post. I turned my volume up loud and still nothing.
    64 bit
    Dont you hear this swoosh? listen to it very close there is an swoosh effect all the time and that is really annoying
    The only thing I heard was a low "thud" type sound near the end. I had my sound turned up max. I just listened to it again and I barely heard something, but it was like the mic volume was turned up to max and it was picking up any movement, breathing, etc.
    I have a recording studio so I'm attuned to mike sounds and noises.
Hello, recently I was having some issues with my sound on my computer (I could not open my volume mixer) so I was given the advice to run a "sfc/scannow" in CMD. The scan fixed that issue, along with generally making my computer faster (I suspect I had some issues with my hard drive aswell). The...
strange printer noises(turned off) in Drivers & Hardware
strange happening: (sorry if i'm in wrong forum) just now - while on net or writing email - suddenly my Brother printer started making 'noises' similar to getting ready to print something ! it's turned off (not wireless) but of course connected to my PC-tower. any ideas? thanks ! ...
Not sure where to put this as I'm quite sure it isn't a hard drive issue per se... I've a weird issue with Windows 8.1 and my mechanical hard drive. I've a 2TB Western Digital hard drive that's partitioned with one of the partitions being a Media partition (H) containing over 107 gig of images,...
Hi there, When I use headphones with my Surface Pro (Win 8) I cant hear the voices in my videos - the background music/sound effects are just too loud. How can I fix this? I have tried using the Win 8 Video player as well as VLC Player and I still get the same issue. I have tried the...
Aloha everyone. I just bought a Dell Inspiron laptop 17i17RM-2419sLV almost a month ago. Today the computer has started making a soft clicking noise that goes in sync with the flashing hard drive light. Is my hard drive bad already? Suggestions? I'm in grad school and can't afford for this...
Basically my PC has always (last few years) randomly just shut down after I boot it up or freeze, but after the initial few resets it would be fine until I turned it off. Today it did it's usual of freezing up (at login) I held down the power button then waited then turned it back on, but instead...
PC won't boot making cycle of whirring noises in BSOD Crashes and Debugging
