Selecting audio input to use with laptop camera
    windows 8.1
    I'm using a Dell XPS 12 running Windows 8.1. Connected via USB is a Focusrite Scarlett 18i6, which sends the computer a digital audio signal (the Focusrite is an outboard preamp and analog to digital converter). When I run a DAW such as Ableton Live, I have no trouble selecting the Focusrite as the audio source.
    The problem: I want to record footage of me playing using the laptop's built-in camera. When I use the Camera app, it always chooses the laptop's crappy built-in microphone as an audio source. It doesn't give me the option of choosing the Focusrite as an audio source.
    I'm guessing there is no way to fix it; there are almost no options for configuring the built-in Camera app. But perhaps there is another Win 8.1 app which doesn't have the same stupid limitation?
    Have you looked at the Sound Panel/Recording Section? May be a setting there that will allow you to use a mic connected to the Focusrite unit?
    (I have a (Sonar) recording studio).
    windows 8.1
    Thanks for replying. I don't know why, but the problem has self-resolved. I tried using the Camera app this morning and for some reason, when I went to Settings, there was an option to select the audio source! It hadn't been there before (even though the Focusrite was connected at the time).
    As a footnote: Before the problem self-resolved, I tried downloading a different camera app... and, man, was that ever an ugly experience. Apps that flat-out didn't work, apps that served no known purpose, reviews written by spambots and illiterates, apps that didn't show up on a search even though the search term was in the title of the app... The Windows Store is really f*cking broken.
Hi guys, i'm stressing out right here, i've been reading threads after threads about this problem and none of the solutions work on me, so i decided to create an acc here and post my thread, hope you guys can help me :/ So i've just installed the Windows 8.1 PRO x64bit on my Asus N55SF laptop...
I'm using an MSI GS70 laptop and just recently ran into a problem where my audio device suddenly stopped working. I spent about 2 hours trying to fix the solution with what I could find online but unfortunately it didn't work. I just did a clean reinstall of Windows 8.1 and the problem continues to...
My laptop crashes when left/right clicking any large movie file over 10gb. I don't experience any BSOD - just a frozen screen. I'm forced to power off each time. Things I've tried: Defragmentation CC Reg Cleaner + General Cleanup Malwarebytes Scan Scannow
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
No audio input and output in Sound & Audio
Well, things went on until noon yesterday, but suddenly My PC takes no audio input or gives any output. I have tried reinstalling driver, checking mute button, checking Cables etc, none of the audio devices work on my PC which work in other devices. On opening realtek audio manager and playing...
So my Laptop does accept HDMI as Input to. But i dont know about any program, that can watch what is being put in. Does someone know one?
