sound is glitched
    Windows 8 64 bit
    sound is glitched
    So I'm running windows 8. When i go to the sound options in control panel, i do the test button. I get the right sound. But this is on my headphones. For my speakers, everything is fine. But when i plugin my headphones they work as my speakers.. And when i do the test sound, it works. When i go on ANYTHING else, the sound is glitched or when i hear a song i dont hear the voice. plz help..
    Are you saying the test tones work OK on both the speakers and headphones, but other sound on both the headphones and speakers bad?
    Please clarify.
    Also, please fill in the "My System Spec's". It helps us to try and help you. And are you on Windows 8 or Windows 8.1?
    Win8.1
    Are you plugging your headphones into the "speaker jack (line-out)"or a "USB" port?
    Windows 8 64 bit
    Okay, I got windows 8.1, but when i use the speakers, all sounds work, when i plug in the headphones, the test works, but not sound.
    As previously asked, what type of headphones? Do you have one with a 1/8" stereo plug or do they connect via USB?
    Windows 8 64 bit
    they connect to the thing to make headphones work, the hole by the mic hole.
    Do you have another PC (or a friend) that you can try that headset on to see how it works. Or a different headphone to try on this PC.
    Windows 8 64 bit
    i tried my earbuds and there was messed up sound, so its my computer ;-;
    You still have never filled in the "My System Spec's" so we have no idea what type of PC you have.
    If this is a desktop, plug the headset into the rear green speaker jack and see if the headphones work OK or not.
    Windows 8 64 bit
    i have an asus laptop
Page 1 of 2 12 LastLast
sound is glitched
Hi everyone, I was playing with some screenshot maker software and I was setting some shortcuts. I unfortunatly pressed Alt+Shift+Printscr and the Windows' theme changed to High Contrast. When I pressed the shortcut again the theme changed back to normal, but the system font kindof "glitched" and...
Repairing a glitched up HDD in Installation & Setup
Hello, My Wife's Laptop Hard drive went belly up. It is a "Momentus 750GB hybrid drive. I moved it to my desktop PC and ran "7-data Partition Recovery" on it. After several days and hours of work. I now have what appears to be the entire recovered HD approx 700GB of file data on an external...
Windows 8.1 .bat file glitched in General Support
Hello, I am having a problem with .bat opening I accidently made if open with notepad and then after getting even the .reg files to merge into registry and restart it didn't do anything so i completely re-installed Windows 8.1 and and its still opening as notepad.
Hey guys, please bear with me. I done messed up! I had a windows 8 partition running successfully. I now cannot boot into windows as the computer (and my linux live cd) wont recognize my main partition and it shows up as 'unallocated space'. Here is how I made this mess: -I used EaseUS partition...
