sound is glitched
  1. #11
    That's fine. Now what is the EXACT model number.
    See my system specs for what we really need.
  2. #12
    I can't get anywhere with the ASUS site, to get the audio specs. However they note THX and EAX which are software enhancements to the basic audio. One of those may be causing the problems. Check the configuration of these programs.
  3. #13
    Please post any info or comments here, not a PM to me.
  4. #14
    Windows 8 64 bit
    Remember, im not to good with this... So you got to teach me, but i got the exact thingy. G73JW-A1
  5. #15
    Windows 8.1 64 bit
    It's the headphone port (the hole beside the mic hole) because if your built in laptop speakers work and the multiple headphones don't work then it's the port. I would recommend cleaning the port (blowing it out, getting a thin brush, etc.)
    -Tallon Kellogg
  6. #16
    Shadow Tech, the headphone jack works as he reported he hears the test tones.
    Do you have the Speakers set as "Stereo"? If they are set to 5.1, 7.1, etc that could be the problem.
  7. #17
    Windows 8 64 bit
    Okay Shadowtech.
  8. #18
    Windows 8 64 bit
    Shadowtech, it didnt work.
Page 2 of 2 FirstFirst 12
sound is glitched
Hi everyone, I was playing with some screenshot maker software and I was setting some shortcuts. I unfortunatly pressed Alt+Shift+Printscr and the Windows' theme changed to High Contrast. When I pressed the shortcut again the theme changed back to normal, but the system font kindof "glitched" and...
Repairing a glitched up HDD in Installation & Setup
Hello, My Wife's Laptop Hard drive went belly up. It is a "Momentus 750GB hybrid drive. I moved it to my desktop PC and ran "7-data Partition Recovery" on it. After several days and hours of work. I now have what appears to be the entire recovered HD approx 700GB of file data on an external...
Windows 8.1 .bat file glitched in General Support
Hello, I am having a problem with .bat opening I accidently made if open with notepad and then after getting even the .reg files to merge into registry and restart it didn't do anything so i completely re-installed Windows 8.1 and and its still opening as notepad.
Hey guys, please bear with me. I done messed up! I had a windows 8 partition running successfully. I now cannot boot into windows as the computer (and my linux live cd) wont recognize my main partition and it shows up as 'unallocated space'. Here is how I made this mess: -I used EaseUS partition...
