Sound only works when I constantly change my volume
    I have an issue where I can only hear sounds when I constantly change my volume on the slider. If I don't change my volume, then my audio fades away in about two seconds. Can someone help me fix this problem?
    Additional information: I have a Logitech USB Headset H390, Running Windows 8.1
    With a USB headset the Headset or its software controls the volume, not the PC's audio.
    According to Logitech, no extra drivers are needed as it is "plug and play".
    Recycle the Headset and see if that helps. Plug it in then go to the Device Manager, RIGHT click on the entry for the headset to highlight it and then Left click "Uninstall". Then disconnect the headset from the PC and restart the PC. After Windows starts, plug it in and Windows should detect it and install it like a new install.
    Tried doing what you told me, still have the same issue
    Win8.1
    Are talking about the volume slider bar on the headset cord (my headset has a thumb-wheel volume controller - so I'm thinking maybe you have a slider control on the headset cord)?
    If that is what your talking about moving to get volume working - then that points to a dirty/failing contact in the slider mechanism. Maybe some "electrical contact cleaner" sprayed into slider would help - or some compressed air (canned air) if you have that handy.
    Quote Originally Posted by CountryBumkin View Post
    Sorry for being vague, I meant the slider in the volume mixer for windows
I wanted to change my laptop's startup sound to a custom sound and saw a guide on the web, and so I went by: Control Panel > Hardware and Sound > Sound > 'Sounds' tab But then I cannot find the 'startup' option in the list of 'program events'. I checked thoroughly but I still could not find it....
There is a very annoying issue with my Windows 8.1 Pro 64 bit. For some unknown reason sound stops working several times a day. Audio usually crashes when I start, pause/unpause or stop a video (XBMC, KMPlayer, Youtube), music, game, or anything that involves sound. The only thing what can make...
Whenever I'm in the Windows environment (meaning not doing anything in full-screen mode), the "Device Eject Sound" (the little do do do do that plays whenever you eject a device) will constantly play at almost random. Sometimes itll play three times in a row right after the other, sometimes it wont...
When I boot the sound volume is whatever I left it when I shut it down last time. I want to reset it to 20 each time I boot. Is that possible?
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
I have set the volume mixer to low volume for "System Sounds." However the UAC alert sound seems always to be at maximum volume, which is not tolerable. My only solution so far has been to mute System Sounds completely in the volume mixer. At least that shuts that loud UAC sound off. Is this...
