can't get usb-headset microphone to work on HP ENVY 700-30
    Windows 8.1 (64-bit)
    Hi,
    Can anybody help me with the following problem ?
    I have a HP ENVY 700-301nd with Win 8.1 and a Sennheiser PC 333D G4me usb-headset connected to it.
    The audio (music, games) sounds perfectly, but the microphone only seems to give crackling and very distorted noises.
    When I plug the headset into my older Win 7 computer, the microphone sounds crystal clear, so it's not broken.
    I've been busy for quite a few hours now, but whatever I do...I can't get the microphone to work on the HP ENVY it seems.
    Installing the lastest drivers from HP and Sennheiser didn't solve the problem.
    So does anybody has a clue what might cause this problem and how to fix it ?
    What do you have listed for the Default Recording Device? Stereo Mix should be set as default Recording Device.
    Stereo Mix (IDT HD Audio CODEC) is listed as Default Recording Device, but when I do that, there isn't any sound at all anymore...like Stereo Mix isn't picking up any sound.
    On the microphone's vu-bar I can see that there is sometimes noise...even though the microphone is switched off on the headset.
    When listening to it, it seemed to be a bit of distorted rumble.
    I just checked that headset. It is USB but according to the site it has separate headphone and microphone connectors. If this is the model you have, then it IS using the PC sound card. If you are plugging into the front Microphone jack, try using the rear Pink microphone jack to see if makes any difference. (You can use the rear Green speaker jack for the headset portion while testing).
    The headset has a small external soundcard that is connected using a USB port.
    The external soundcard makes it possible to get 3D surround sound...wich is working like a charm.
    On the external soundcard there are 2 jacks...1 green and 1 pink.
    So that is how it should normally work
    This is a unboxing movie on youtube, to give you a very good idea on the headset that I'm using.
    https://www.youtube.com/watch?v=ZrCPdnMfYsE
    I tried disconnecting the pink connecter from the external soundcard, and connecting it directly into
    the front and rear Microphone jack, but no matter wich one I try...the PC tells me there is no microphone connected.
    Edit:
    In the box was a short extension cord that I used.
    However, I noticed that the guy in the youtube movie said that extension cords could give problems with the microphone.
    So I removed the extension cord, and plugged it in directly into the usb-port on the PC.
    And now I can actually hear myself talking when I check...
    So I will do a few more tests to see how it works, and than report back.
    Last edited by TheDJ; 26 Jun 2015 at 05:20. Reason: Tried something I noticed in the youtube video
    Did run a few tests like Skype echo, and all seemed to work...or sound...perfectly now.
    It only still amazes me that Sennheiser put an small extension cord in the box wich can give problems so it seems.
    The extra adapter, that I saw had a 4 conductor adapter, that would be used on devices such as an iPhone, PS/4, etc and NOT for a PC.
    As you can see it's a small external adapter/soundcard with only 1 green and 1 pink connector.
    You plug it in on a usb port, install it's drivers, and thats about it.
Hi, I recently bought a new headset due to one of the ears falling apart... My old one was USB with a 3.5mm cable and worked perfectly fine. The new one I got has no USB and uses the green and pink cables. I've plugged them in and it seemed as if they were working well but I realised they're not...
I currently have a Sennheiser PC 360 that I used on a previous build, which I paired with a ASUS Xonar D1 sound card on Windows 7. I recently put together a new build using Windows 8.1 and now the mic no longer works. I receive audio output through the headset speakers just fine, but the mic acts...
So the other day i bought a Logitech for 15 and i get home to recorded my voice but my laptop wont pick up my headset..Like it knows its been plugged in etc and will even play sound through the headset but can seem to get it to pop up on my microphone bit! Could someone help me please?
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Can't get headset to work in Sound & Audio
So today I got a new acer laptop with windows 8. The laptop only has one audio/microphone input in it. When I first plugged the headset microphone jack into the singular input, it asked what device it was. I selected headset and moved on. Later, I could not find my headset mic in my audio...
