Audio Drivers Messed up!!
    windows 8.1
    Hi,
    Unintentionally, the Realtek Audio driver was uninstalled -therefore, no sound.
    When I did a search for the appropriate driver and finally was installin this one -http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=D3P06
    An error pops up . I've attached a log.
    MY SPECS.
    Dell Inspiron 15 R Series
    Audio_Driver_D3P06_WN_6.0.1.5975_A04.txt
    Win8.1
    You could try the Realtek generic audio driver. It won't hurt anything. Realtek
    windows 8.1
    Quote Originally Posted by CountryBumkin View Post
    Thank you very much, it worked !!!
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
I'm running win 8.1 update, from a fresh install and the drivers out of the box run my sound card perfectly well. It does all I need to do even muting speakers when headphones are plugged in. Should I install the downloaded realtek x64 drivers or not. Opinions? Edit: Answered my own question I...
Hey all, I have an Asrock Pro4 Z77 with ALC892, running Win 8 64bit Pro. So I wanted to install new drivers for this audio device and downloaded the R2.70 drivers from Realtek.com and installed them without a hitch. However, when I went to the Asrock website and clicked on my mobo I saw...
Hi all, I've tried searching both this thread and elsewhere but I can't find a solution that works for my issue. I just upgraded my Sager NP6165 laptop to W8 and updated all the drivers (chipset, wireless, etc.) using the Sager websites latest drivers and everything went well except for the fact...
Can't install audio drivers in Drivers & Hardware
My computer came with a disk with audio drivers for it, but when I try to install them, it saids that i need to be on win 7. I mean I can hear sound just fine, but without the drivers I can't use my mic. Any help would be nice, and thanks in advance.
Realtek HD Audio 2.68 audio driver download from Guru3D.com To easily install, go to device manager first. Then right click the Realtek audio, choose uninstall and also check the box to delete the driver. This saves you a reboot in the process to install. When you run the installer, it won't...
