changing from wireless headset to.........................
    to the desktop speakers while the headset battery is being re charged. I have windows 8.1, and the PC I have is dell inspiron
    660.
    If your PC has different listings for the Audio Playback Devices you can manually change the default playback device from the headset to the "Speakers" (PC audio) in the Sound Panel, Playback Section.
    If yours does not have a separate listing for the headset, use an external charger.
    got it, thanks for your help.
Hi, I bought some phillips headset, and I plugged it into my asus n551jk, worked fine, no problems, then I started to fiddle with setting in the realtek HD audio manager, I changed the sample rate, and the headset stopped emitting sound, I changed it back to where it was(default) and it still...
so i got an msi gaming z97 micro atx board, but on the io i cant find where the hell to plug in my headset.... there is a mic and the l-output and input well 3 inputs and 3 outputs. i checked the manual but it didnt say it. 56997
Please can you assist with my wireless connection issue. I have just recently purchased the RTL8192CE wireless Lan 802.11 PCI-E NIC and installed it in my shuttle XPC. I am using Windows 8.1 64bit OS. The LAN card is picking up my wireless router fine, but when I enter my router password an...
Logitec 960 USB Headset in Sound & Audio
Please could you help? If I unplug my headphones and plug them back in again the sound continues to come through the speakers and not the headset.The only way I can resolve it is to restart Firefox. I have posted in the Logitech support forum but no one replied. Thank you
Can't get headset to work in Sound & Audio
So today I got a new acer laptop with windows 8. The laptop only has one audio/microphone input in it. When I first plugged the headset microphone jack into the singular input, it asked what device it was. I selected headset and moved on. Later, I could not find my headset mic in my audio...
Cannot Remove BT Headset in Drivers & Hardware
I was trying to remove my BT headset from BT devices and now its stuck on "removing device"... won't remove...won't even let me connect the headset now :/ even tried removing them from device manager, after a the device appears again :/ the screenshot is attached
No sound using 360 headset in Sound & Audio
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
