Sound Worked in Consumer Preview but not Release Preview
    My sound used to work in the consumer preview fine but since I upgraded to the Release Preview I need the volume max and headphones in to hear anything. Any help appreciated. If more info is needed just ask.
    Check in your Device Manager whether you have this driver,
    Quote Originally Posted by brummyfan View Post
    I have two listed. It could be the driver. I have a generic MS one. Where do I go to see the company make and model of my soundcard.
    In the same window(High Def Audio Device Properties) click Details tab and select "Hardware Ids" from the dropdown menu.
    EDIT: Generic Windows driver should be sufficient, give sfc /scannow a try before using manufacturers drive using the second option in this Tutorial:SFC /SCANNOW Command - Run in Windows 8
    I did that and the cmd prompt said:
    Windows Resource protection did not find any integrity violations.
    Then look for the drivers from manufacturers and if that doesn't work, a clean install might solve the problem.
    How do I find out the manufacturer of my sound card?
    Quote Originally Posted by carstorm View Post
    Download and install this free utility: Portable HWiNFO64 Download - Softpedia
    EDIT: Or go to control panel (small icon view), click Administrative Tools, click System Information and view Audio Manufacturer under Components.
    That said ever one was Microsoft but I know their not. After look around I found "SRS Premium Sound" engraved my my pc. I do a search and found out its by relteck like many other parts of my system. However I can't find the windows 8 driver for it now. I'll keep searching but if anyone comes across a download please post it. TY
    Try the driver for window 7 from here and let us know whether it helps.
    Realtek Definition Audio Codecs
Page 1 of 2 12 LastLast
I have an HP TX2000 laptop/tablet convertible. I was using the preview release of windows 8 with no problems at all, touchscreen stuff worked great. Now that I bought windows 8 (specifically because it worked so good on this laptop) my touchscreen isn't working with my hands. When I check system...
When I updated to the release preview, Metro stopped working on my computer. The tiles said Microsoft.ZuneMusic/AppexNews and when I clicked them they did not open. If I tried to open the store, it would open the splash screen and then crash. So then I tried to re-install windows 8 but it would not...
The serial number listed on the MS website will not take on the upgrade. Any suggestions?
Hello, I downloaded the Windows 8 Developers Preview in September last year and have been offered the Consumer Preview through DreamSpark today. I haven't installed either but I have the Developers Preview already downloaded. Is there a difference? Is it big? Which would you recommend? ...
Hi,can Win8 C.P. be installed without removing Win8 D.P. I guess not, but since until now my Revodrive 3 X2 gave me problems with the Win8 D.P. install, i hate to do a fresh try with the Consumer Preview. I would loose the Win8 is am using now. When starting the setup, hard drive is not...
