Sound Worked in Consumer Preview but not Release Preview
  1. #11
    England
    Windows 8 release preview
    If that doesn't work then uninstall the driver for it then let windows 8 install the driver its self.
  2. #12
    That's what started the trouble and I tried already.
  3. #13
    England
    I didn't notice that bit when I looked through it but I can't see why it wouldn't if it worked in consumer preview unless you had the of the website for it for windows 7 installed.
    In fact I have noticed alot better compatibility with the stuff I use on release preview than on consumer preview.
  4. #14
    On the consumer preview I didn't have to change anything it worked fine from the start. Now it only works when I have headphones in.
  5. #15
    Hi carstorm, did you do a upgrade install or a clean install?
  6. #16
    Clean Install. There is no way to upgrade from the consumer preview to the release Preview.
  7. #17
    I am running out of ideas, I would suggest you to "Reset" after saving all your important work, if that fails do a clean install.
    Reset Windows 8
  8. #18
    Quote Originally Posted by brummyfan View Post
    Reset Windows 8
    I'll try that tonight and let it do it in the overnight Hours
  9. #19
    Hi carstorm, there's a new Realtek drivers available, try that before Reset or clean install, might save you unnecessary work.
    Latest Realtek HD Audio Driver Version for Windows 8
  10. #20
    Too late I already did a clean install. I'll try it anyways though because I still only have audio when I have headphones plugged in.
Page 2 of 2 FirstFirst 12
I have an HP TX2000 laptop/tablet convertible. I was using the preview release of windows 8 with no problems at all, touchscreen stuff worked great. Now that I bought windows 8 (specifically because it worked so good on this laptop) my touchscreen isn't working with my hands. When I check system...
When I updated to the release preview, Metro stopped working on my computer. The tiles said Microsoft.ZuneMusic/AppexNews and when I clicked them they did not open. If I tried to open the store, it would open the splash screen and then crash. So then I tried to re-install windows 8 but it would not...
The serial number listed on the MS website will not take on the upgrade. Any suggestions?
Hello, I downloaded the Windows 8 Developers Preview in September last year and have been offered the Consumer Preview through DreamSpark today. I haven't installed either but I have the Developers Preview already downloaded. Is there a difference? Is it big? Which would you recommend? ...
Hi,can Win8 C.P. be installed without removing Win8 D.P. I guess not, but since until now my Revodrive 3 X2 gave me problems with the Win8 D.P. install, i hate to do a fresh try with the Consumer Preview. I would loose the Win8 is am using now. When starting the setup, hard drive is not...
