Headset stopped working after changing sample rate
    Hi, I bought some phillips headset, and I plugged it into my asus n551jk, worked fine, no problems, then I started to fiddle with setting in the realtek HD audio manager, I changed the sample rate, and the headset stopped emitting sound, I changed it back to where it was(default) and it still doesn't work, I've been around this for 3 hours and I'm going insane, I've tried restarting, uninstalling drivers, etc, nothing works.
    What can I do? Headset still works on my phone, so I know it works.
    Check the Advanced Settings. Mute speakers should be checked.
    See this.
hello guys. im using win8.1 and i am having bit problem with Xonar d2x settings.in control panel .i have selected 6 channesl and want to choose DTS with sample rate 192khz.but after restart sample rate comes back to 44khz, i have already try to change settings i control panel...
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
Hi all, I am organizing my mp3s using this pc with windows 8.1. For the columns so far I have the name, #, artists, album, type, size, bite rate, length, year, publisher, which is perfect so far, however, I also would like to add the sample rate of the mp3, however, I am unable to find the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
Hello~ I was recording with my internal realtalk hd mic on my laptop, but it stops working everytime I plug in my head set. There's nothing special about this headset, and there's no microphone on it. Sadly, my RT mic does this with any headset I use. It's frustrating when I unplug my headset and...
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
I have a Genius150 watt 5.1 speaker system Genius I dont have the realtek driver installed since the sound quality was not satisfying with it so I stayed to the default high definition audio device with stereo configuration. I have an integrated sound card. This is my motherboard model GIGABYTE -...
