Couldn't find sound card and there's no sound
    Mac Boot camp with windows 8.1
    Hi. I actually uses a macbook and bootcamp windows 8.1 in it. On windows 8.1, i tried listening to music but there's no sound coming out. i check the audio but there's a detection that the sound is playing but weird, not a sound can be heard from the video i was playing. It will only produce sound when i plug in external speaker. It means that, if i dont have a speaker and just on a video, no sound will come out even though there's a detection. What should i do ?
    Windows 8 Pro 64-Bit
    You can attempt to experiment sending sound to various outputs. Please go to Control Panel > Hardware and Sound > Sound .
    While under Playback tab, do a right click on any white area make sure "Show Disabled devices" & "Show disconnected devices" are checked. Take a screenshot of it and please upload it to us.
    Since you are here try right clicking on all of the devices and selecting Test option for each device.
    If you are able can you please double check Device Manager ? Press + R (On your keyboard at the same time. Then type devmgmt.msc
    Tutorial on how to upload files and pictures (I recommend using the sniipping tool)
    Screenshots and Files - Upload and Post in Seven Forums - Windows 7 Help Forums
    Thanks for the solution ! It finally worked well and i can play the sound successfully ! ^^
A couple of days ago, I decided to move my tower from my desk to the floor. Everything was working beautifully up until then. I opened it up and removed some dust. After putting it back together, the monitor wouldn't register anything. I left it for a day, came back, and the monitor magically...
Sound card scenario in Sound & Audio
My existing audio output jacks on the motherboard look like this: ...
I accidentally deleted my IDT sound driver for my HP Pavilion G7 laptop. I was going through the programs that I wanted to uninstall and came across the sound driver. Not knowing that it was an important part of my computer, I deleted it. I've tried downloading it again from the internet, but the...
Sound Card not working in Sound & Audio
Sound Card Recommendations in Sound & Audio
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Solved Sound Card Issues in Sound & Audio
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Virtual Sound Card? in Sound & Audio
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
