Solved Digital Audio (HDMI) only has 2 channel option
josephdebono
Hi,
I've been running on W8 Consumer Preview since release without any trouble at all. Yesterday I installed the Release Preview and I've encountered a problem. My PC outputs to the amplifier via HDMI on my graphic card (Radeon HD 6700). The problem is that in the speaker configuration from playback devices only allows me to select 2 channel audio, and has no option for 5.1, so anything which tries to play 5.1 audio will result in no sound output.
I've installed the latest release of the Catalyst Control Center released 31 May (for Windows 8 RP). This was all working perfectly under the Consumer Preview.
Any idea how to get it to work?
Edit: I know HDMI is not selected as default device in the screenshot above. That's not an issue as XBMC always outputs from HDMI irrespective of my default choice.
    Windows 8 RP
this is quite normal.
all digital outputs cannot be configured in windows - this is why you can only see 2 channels. this setting applies only for analog audio as it is processed by windows. As it is digital signal streamed to external decoder - windows setting doesn't mean anything, correct format is encoded by source app and decoded by ext. device.
i tested it on 2 different computers, with hdmi, digital coax and spdif.
if u get no sound over hdmi at all - try to install different driver.
    8 Pro + MCP
    DIY
    core i7 3770K @ 4.8GHz
    ASUS Sabertooth Z77
    Crucial Ballistix Elite 4x4GB 1866CL9
    intel HD4000/integrated
    7.1/integrated
    23" IPS Calibrated
    OCz Vertex3 60GB SSD
    WD Scorpio Blue 500GB
    WD Caviar Blue 500GB
    Seagate Momentus 160GB
    Hitachi TravelStar 160GB
    OCz ModXStream
    modded CM Cosmos S
    DIY watercool
    Roccat ISKU, Razer Nostromo
    Razer Orochi
    I build, tune, mod and overclock.
    Want a really cool rig? I can do it for any budget!
The problem seemed to be that the Catalyst drivers provided for W8 by AMD do not contain the HDMI Audio drivers by Realtek for the HDMI Output. I managed to track down this fact using the vendor and device ID and then got the Windows 7x64 drivers for the ATI HD Audio.
Now 5.1 is selectable from the speakers under HDMI audio and everything is working fine:
    Windows 8 RP
I'm having the same issue with a 6870.
Do you have a pointer to the driver you used? I tried one of the Realtek HDMI audio drivers, but it must've been the wrong one as it didn't work.
    iOS
Hi,
I have the same problem: Digital Audio (HDMI) is Greyed Out. Image goes to my Receiver/TV, but no Audio.
My System:
Dell XPS 15z notebook
NVidia Geforce 525M
- I installed NVidia Driver 302.80, release a week or so.
- Installed Realtek Driver from the previous post
- Tryed to install the HDMI_R270.exe, but this seems to be an ATI only driver.
I'm using Win8 RP 64-bit.
Appreciatte any help, thanks.
PS: After installing INtel HD 3000 driver and reinstalling NVidia and Realtek, I have only the "speakers" icon under SOUNDS. Not even the greyed out HDMI icon...
    Windows 8 - 7
    Dell XPS 15z
    Core 7i
    8 GB
    HD 3000 - NVIDIA GeForce GT 525M
I have the same problem and it's driving me mad!!
Running an ASRock A75 Pro4-M motherboard and trying to use the onboard HDMI.
By default the Microsoft driver is installed.
I've tried installing the latest drivers form both Realtek and ASRock, and in both cases the installation does its thing but the driver still remains the useless Microsoft one.
If I try to manually update the driver to the one I downloaded, it tells me that the "best" driver is already installed and will not switch away from the Microsoft driver. WTF?!?!
    Windows 8 Release Preview
    AMD A8-3870K
    ASRock A75 Pro4-M
    8GB G.Skill DDR3 1600
    Onchip Radeon 6550D
    Onboard
    32" Samsung LCD TV
    WD Caviar Green 1TB
    Seasonic X-460 Fanless
    Lian Li C37
    Scythe Shuriken Rev B
    Logitech bluetooth w/ trackpad
Hi chaps.
A fellow sufferer from the same 'stereo only' option via hdmi here.
I recently completed a custom gaming HTPC build and am running audio from an Asus AMD 7770 over HDMI to a Sony STR DH800 receiver using Win 8 64-bit release preview.
I've been trying for days to try and resolve this but no luck as of yet. I've tried a multitude of Catalyst and Realtek drivers (Win8 +Win7, including the one mentioned by josephdebono) but whatever happens, I always seem to end up with the default Microsoft driver for the 'HDMI Audio Device', and as a result just the option to use 2 speakers.
I wonder, why then, the 3rd party catalyst/realtek drivers don't appear to be installing over the MS one. One thought is, I have disabled onboard audio. I can't see how, but is there any way in which this could impact upon the driver installation for the HDMI on my graphics card?
I'm fairly certain this isn't related to my receiver as I've used it with a laptop running Win7 via HDMI and had no problems getting 5.1.
    i3 2120
    MSI H77MA-G43 H77
    8 GB DDR3
    Asus AMD 7770
    AMD A8-3870K
    ASRock A75 Pro4-M
    Onchip Radeon 6550D
    Onboard
    32" Samsung LCD TV
    WD Caviar Green 1TB
    Lian Li C37
@Steyr,
Thanks for the reply.
After looking at that thread it seems as though I'm having the same issue as you were, the only difference being that you're using onboard HDMI vs HDMI on the video card. Hopefully it won't matter though, I'll certainly take a look at that driver later tonight and see what happens.
    i3 2120
    MSI H77MA-G43 H77
    8 GB DDR3
    Asus AMD 7770
    Windows 8 - 7
    Dell XPS 15z
    Core 7i
    8 GB
Well I managed to solve the problem thanks to Steyr's link to the thread that Bart666 posts a solution.
If anybody else is having issues I will reiterate the precise steps I followed to solve the problem:
It appears, for whatever reason, the latest version(s) of catalyst drivers will not install the necessary HDMI audio driver for the 7770 graphics card. Whether or not this relates to my particular model of card and/or OS version (Windows 8 64-bit Release Preview), I don't know.
In order to get the device working correctly (and obtain full 5.1 channel audio as a result) was to obtain the Hardware ID which can be done by the following:
Start -> Control Panel -> Device Manager -> Sound, video and game controllers -> *audio device* -right-click, Properties -> Details Tab -> Select 'Hardware Ids' from the 'Property' drop-down menu -> right-click 'Value' and select copy
Paste this into Google to (hopefully) bring up drivers that specifically mention compatibility with the designated audio device, install and hope for the best.
As it happens, it was version 11.4 Catalyst drivers that did the trick for me. I was able to do a custom install and select just the AMD HDMI Audio Device driver, which, upon restarting was fully functional.
    i3 2120
    MSI H77MA-G43 H77
    8 GB DDR3
    Asus AMD 7770
I have a Geforce 240 and use Windows 8 retail. Even though Windows 8 installed the Nvidia video drivers, it did not install the Nvidia HDMI audio drivers. Installing the latest drivers from Nvidia fixed this problem for me. I did not need to change any other settings. Once the Nvidia HDMI audio driver was installed, it asked to reboot, after the reboot my 5.1 channel setup is working.
    Windows 8, Ubuntu 12.10
Me too. As soon as I installed Win 8 retail, my problem went away. Sorry for not posting this earlier to help others as the post above.
    Windows 8 - 7
    Dell XPS 15z
    Core 7i
    8 GB
I've just been having the same problem with only 2 channels appearing on my AMD HDMI device. The problem was being caused by my Onkyo receiver. I had HDMI passthrough enabled on the receiver. If I turned the receiver off before the TV, the PC only saw a 2 channel device (the TV) which is why the 7.1 option was missing. As soon as I disabled HDMI passthrough the 5.1 & 7.1 surround options appeared in the speaker setup.
    Windows 7
Im still having issues can u possible help? it still wont show 5.1 at all
    Windows 7
This is what it shows, what should i download? plz plz help
HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002
    Windows 7
