Audio Jack Problems (Dell Inspiron 15 3537, Windows 8.1)
    Hi, I have a problem with my front audio jack. The cause of this problem may or may not be the DAW reaper. I set my front headphone jack on my laptop as reapers input and the speakers on the laptop as its output. This did not work so I uninstalled the program. I tried to use my headphones but there is nothing. I uninstalled all the drivers for Realtek and reinstalled them. I have also tried system restores, 4 times. They keep failing regardless of whether Avast is off or not. The speakers work, and when the headphones get plugged in (they work on my phone and other PC's in the house perfectly fine), they are recognized by Dell Audio. The problem is, the only thing in the playback tab in sound (hidden or not) is speakers and a monitor I don't want to use. Can anyone help me diagnose the problem? I really want to use my headphones again.
    Click image for larger versionClick image for larger version
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    I have 3 Dell Inspiron 15 Notebooks [1 bought new and 2 resurrected] and have only the one Headphone jack on them.
    Maybe your device needs the Microphone jack for the input of audio instead of the Headphone/Speaker jack?
    Well, my laptop only has the one jack. When I plug in the headphones, it recognizes them, and asks what kind of device it is. I'm not sure how I could do what you said, as they are skull candy crushers, and I have used them and the mic through that one port for a long while (january)
    Forever West
    Your Inspiron must be newer than mine. Since the port is designed to use either a headphone or a microphone it may not be possible to use a Y-cable and separate the devices plugged into it but I would wonder about the use of a headphone that includes a microphone, have only seen those that use both jacks.
    Mines a mid 2013 model. There is no need for splitting the cable as it only needs one input... The mic and headphones have worked perfectly until now. Any suggestions that could be of any use?
    I have a recording studio. If you want to use it for recording I would seriously consider a USB connected recording interface unit and not the PC audio, which makes a poor recording device. The problem could also be Reaper and how its configured. I don't use Reaper, I use Sonar so I know nothing about how to configure it.
    I know that USB is better, i just wanted to try this. Now does anyone have any suggestions on how to fix this?
Hi, my PC (Dell Inspiron 15, 3537) used to work really smooth at start ups with Windows 8, but since I updated to Windows 8.1 my PC's start up time became really very slow. It nearly takes 3 - 4 minutes to start up with Windows 8.1. While with the Windows 8 it used to start up in like less than...
BSOD - dell inspiron 17 7000 windows 8.1 pro in BSOD Crashes and Debugging
I have had my Dell Inspiron 17 7000 for about 3 months now and have recently (last two weeks) begun to experience a BSOD with the message DRIVE_POWER_STATE_FAILURE. I have run the diagnostics program (results attached) Any help would be much appreciated Ian
Hi. Yesterday, I restored my Inspiron 15 to it's factory settings. Post-reset, I installed all drivers for Windows 8 directly from the Dell website except for the AMD driver which I took from the AMD website (just wanting to get the latest directly from the source, I guess). I also used that...
I have a Core i5 Dell Inspiron N5110 with 4 GB Ram.I tried Clean Installation of Windows 8 64 Bit (Downloaded From Microsoft Dreamspark Account) with bootable USB many times about every possible management of partitions but it goes black after the installation ,where it says "Getting Device Ready @...
​I installed the Windows 8 Release Preview Evaluation copy, Build 8400, on my Dell Inspiron E1505 and it works just fine. I'm wondering if I can expect an upgrade to Win 8 Pro to work as satisfactorily, or might I expect trouble? Here are specs: Intel Core Duoprocessor T2500...
Hello All, I thought I would post an interesting Installation of Windows I did on my Dads 2006 Dell Inspiron 6000. I am posting it in the Drivers section because Dell never made a Audio driver for the Inspiron 6000 past Windows XP. I had to do this trick for Widows 7, so I thought I would try...
Windows 8 on a dell Inspiron Duo in Installation & Setup
There is video on windows 8 being run on a Inspiron Duo, look good for those who have touch screen, http://youtu.be/wLAMfbo69fw
