realtek audio manager missing
    windows 8.1
    I have the asrock z77 extreme 4 mobo and when i originally installed it it had realtek audio manager on it, but after a while and upgrading to windows 8.1 it doesnt seem to be on my system anymore. I have gone through my files and downloaded the newest drivers to no avail, if anybody could guide me through the steps to fix this, i would greatly appreciate it.
    Harrisonburg, Va.
    Try this link---
    Realtek
    Maybe Realtek will help.
    I Googled it a lot & could not find a good answer.
    Trnava
    Win 8.1.1 Pro x64
    8.1 no longer provides an icon, for whatever reason, you need to open it via control panels.
    Control Panel - Hardware and Sound - DTS Audio Control Panel.
    N.Y.
    Windows 10 Pro 64bit
    Does it show in the Device manager under Sound,Video and game controllers ? Device manager on menu select scan for hardware changes.
    Try running a hardware troubleshooter, open control panel in search box type troubleshoot, go down to Hardware and sound, click configure a device. Try completely uninstall and reinstall again, then reboot PC.
    Edit: Well scratch that if it does not.
    Harrisonburg, Va.
    See if it is in the list of icons for notification area---
    EDIT---
    Mine is in Control Panel & Notification Area---
    Harrisonburg, Va.
    I found mine here---
    N.Y.
    Be kind of strange if it did no longer shows in windows 8.1 in control panel. My Creative shows in the start menu in 8.1.
If I jump forward or back to a different track, if I start a different video in VLC, if I jump back on youtube to replay a part in a video or click on a different video, anything I do and the graphic equalizer in Realtek HD Audio Manager resets. What gives? Thanks!
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
I have Z87 G43 Gaming Motherboard, it is strange that the Realtek Audio manager no longer starts automatically on startup. I see there is no startup icon in that folder. I uninstalled and reinstalled the Realtek software, but still it does not start automatically. Not sure what could be the issue....
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
I'm using a windows 8 pavilion g7 laptop. Long story short, I wanted to have realtek HD audio on my computer mainly for the cool audio effects that come with it because the audio drivers that came with my computer don't have those effects. Nonetheless, I installed realtek HD audio hoping it would...
Hey guys, My audio disappeared and stopped working. my audio icon has a red x on it and when i click it it wants to detect problems (it doesn't work). what should i do? how should I diagnose the audio? I feel like this is hardware problem as it just happened out of the blue. The audio...
