Sound Test Plays All Speakers Music Won't
    Windows 8.1 64-bit
    Realtek High Definition Audio
    Motherboard: B85-G41 PC Mate(MS-7850)
    Speakers: Logitech X-530
    The set includes 4 speakers ( two front and two back), Center, and Subwoofer.
    I'm not using the two back speakers.
    In the RealTek Audio manager's sound test, I hear sound from the front left, front right, center, and subwoofer.
    Under enhancements I have speaker fill checked.
    When I play any music from YouTube, iTunes, Spotify, I'm only hearing the sound from the front left, front right and subwoofer. For some reason it will not use the center. Should I hear sound from the center?
    Another quick thing about this. When I play something from YouTube and it has an advertisement, the sound in the advertisement plays from the center speaker! Isn't that a kick in the pants! Any windows sounds, like new e-mail notification, plays from center speaker. Seems isolated to only music.
    S.E. Texas
    windows 8.1 64bit
    Most music is recorded in stereo. No center channel.
    N.Y.
    Windows 10 Pro 64bit
    True, since recorded in stereo, no center channel. Check in sound properties in device manager, select speaker device then select configure.
    Look in Realtek HD audio Manager make sure speaker fill is set there, also look for virtual surround setting or play with the sound effects tab.
    Works fine for me even though music, but i have all 5.1 speakers hooked up on Creative Sound Blaster card. If no rear speakers is the rear 3.5mm jack still plugged in anyway ? Why do you want it in center channel for music, unless for just talk ?
    Commercials on youtube might be mono or more then 2 channel, reason hear it in the center. Only more effective if had all 5.1 Lot's of software are different, then it also in settings you use, set and way it is hooked up, optical or analog.
    It is working correctly. No music will come out of the center speaker when listening to stereo.
    N.Y.
    Yep, but a lot to do with device software settings, system settings and how it is hooked up. Mine does play through center channel with CD's, Mp3 and Flac. Although mine is hooked through Optical cable.
    I just assumed it would sound better if all speakers were firing. Maybe not?
    N.Y.
    Quote Originally Posted by Lery View Post
    No, not really going make it sound better with center channel playing, would if you use Surround rear speakers though. I said check tab in Audio manager named Sound effects, try different ones, other then that not much more going get in sound with 2 front, center and a woofer, just virtual surround. Have not used Realtek in years to remember it well enough.
The title pretty much says it all. I realize there are other threads out there similar to this, but their solutions either didn't work for me, or the problem wasn't quite the same. My issue is as follows: When I plug my headphones into my laptop (hp dv7t 6c000 quad) audio plays through both the...
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Recently the sound on my Sony Vaio will play initially, but afterwards won't work. It doesn't say it's muted and the little green part that shows sound in the speaker area also doesn't appear when something is playing. I have tried to test the speakers to see if that plays sound but when I do it...
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
Ghost sound/speakers.. in Sound & Audio
Hey guys So this is a weird one... I have a Xonar D2 sound card, and the Xonar D2 Audio Centre, all sound thru my speakers and headphones fine. All music, games, skype are heard and picked up on the D2 Audio Centre just fine. HOWEVER When I open the Volume mixer, almost every program I have...
Hello everyone,after using Windows 7 Ultimate on my laptop for almost 2 years I decided to upgrade to Windows 8. The first day it was working fine,no problems at all. The other day I disconnected my USB mouse and it would keep on playing the disconnect sound, however, I solved that issue. Recently...
We have an entertainment company with DJ's and thought we would give 15 Asus S200E notebooks with very nice all aluminum case, 4gb ram, 500gb HDD, i3 Intel and even external optical drive (which 8 wouldn't let them install) with Windows 8 to our DJ's to use in our business for real life...
