Help: audio stops working after a while
    Microsoft Windows 8.1 64-bit 9600 Multiprocessor Free
    I am having some problems with my laptops audio. The audio always cuts off after a while and doesn't work until I restart the PC. I have installed the newest drivers and also rolled back to the older drivers, I have tried disabling and enabling the sound card nothing seems to be working. After I restart then it works for sometime but after that it stops and none of the playback devices would give out audio . Please help.
    Audio driver details:
    IDT high definition audio codec
    version : 6.3.9600.16384
    System information:
    Intel core I5 , 2.50GHZ , 8gb RAM , windows 8.1 , 64bit
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    Many Notebooks use similar hardware, your System Specs need to be completed.
    System Spec - Fill In Your EightForums System Spec
    Done
    Forever West
    Does the same problem exist when using a headset or earbuds with it?
    Quote Originally Posted by Berton View Post
    Yes, The problem isn't just restricted to the speakers, when I plug in my headphone it still wouldn't work.
    Forever West
    The downside of a Notebook/Laptop is it is hard to change the hardware, usually have to replace the motherboard. Cost-effectiveness comes into play based upon the age, if in warranty and if not whether one wants to invest in repairs with either no warranty or very short compared to the cost a new device. Adding the parts costs to labor costs can equal half or more of a new computer with a warranty.
    If I were working on it I'd boot to a Linux LiveDVD [prefer Mint] and check to see if the problem is hardware or software related, if it works in Linux then the assumption would be it's a Windows and drivers issue.
    United States
    Windows 8.1 Pro 64-bit
    Hi Popeye, I followed the instructions on the HP page you referenced but after I turned my computer back on and tried to install the file from my downloads it said that '' the hardware detected is not supported by this IDT software package , the install will be aborted '' I restarted my Laptop and the sound came back for about 5minutes and then it stopped working.
    @Berton, how do I find out the problem using Linux?
    Forever West
    When Linux loads try playing a song, VLC Media Player is included on the LiveDVD.
Hello, I have a Lenovo G510, and many times (most of the times) when I plug earphones or speakers to the 3.5mm jack, the audio stops, and a red X appears on the Speakers icon in the notification area, and I have to press Solve problem and then it detects that the speakers stopped working (I will...
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
Solved Taskbar stops working in General Support
New Windows 8.1 laptop, one week old, no malware of any kind, working perfectly fine until just a few minutes ago. I have the taskbar customized with shortcuts that I use all the time. Suddenly, clicking one of them does nothing. Whether it's a browser or Notepad or whatever, it simply does not...
Windows stops working. in BSOD Crashes and Debugging
Randomly (or at least I cannot find consistency) Windows will stop working. It will ask me to force stop but I cannot click it because it is frozen. Any open programs will work, if I try to open task manager it wont, and when I Ctrl+Alt+Delete and go to restart it completely freezes up. The last...
For the past few days my laptop, a Windows 8 Samsung model with Intel core i5, has been acting up for the first time since I purchased it last year. I've been away on vacation for three weeks, and have not used it during that period, so when I returned the system naturally installed itself with new...
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
I have WIN 8.1 installed on a Gateway DX 4822IE 10 and now IE 11 continually stop working,can find no fix on MS web site, any ideas on this????
