Windows 8.1 Pro (No Audio Output/Input Device Installed)
    I'm using an MSI GS70 laptop and just recently ran into a problem where my audio device suddenly stopped working. I spent about 2 hours trying to fix the solution with what I could find online but unfortunately it didn't work. I just did a clean reinstall of Windows 8.1 and the problem continues to persist stating that I have no audio devices installed. I'd appreciate it if someone would be able to help me solve this problem as it has caused nothing but frustration for me most of the day.Click image for larger versionClick image for larger version
    Just updating, went into dxdiag and it shows this.Click image for larger version
    Check the BIOS. The audio can be enabled or disabled in most BIOS. If everything is OK in the BIOS, try a BIOS reset (back to default values) and see if that helps.
    You could also run Linux (via a disc) and see if the sound is detected OK in Linux. If it is, that says the sound is working and there is potentially a problem with Windows. If this laptop has an Intel chipset, try installing the Intel motherboard chipset drivers and see if that helps - one of the things the chipset drivers do is identify all the devices on the motherboard.
    BUMP
    I have the same problem, pls help
    United States
    Windows 8.1 Pro 64-bit
    You have so much installed under audio I would disable everything except the the Realtek HD audio. Then uninstall it and reboot and let it reinstall. See if it works with just Realtek audio enabled. Enable the others one at a time and reboot. See if there is one causing the problem.
    gray icons means no device, and i can't enable or disable anything.
    United States
    I missed they are grayed out, sorry. Are you showing hidden devices is that why? I would uninstall/remove all those then do the uninstall of Realtek like I said.
Hi guys, i'm stressing out right here, i've been reading threads after threads about this problem and none of the solutions work on me, so i decided to create an acc here and post my thread, hope you guys can help me :/ So i've just installed the Windows 8.1 PRO x64bit on my Asus N55SF laptop...
i have a dell inspiron 14z 5423 laptop which supports IDT high defination audio driver . . . when i try to insltal it from the site the box says that " the hardware detected is not supported by this IDT .software package . . the install will be aborted . . .but in the dell site it shows that my...
No audio input and output in Sound & Audio
Well, things went on until noon yesterday, but suddenly My PC takes no audio input or gives any output. I have tried reinstalling driver, checking mute button, checking Cables etc, none of the audio devices work on my PC which work in other devices. On opening realtek audio manager and playing...
Hello, I have a Toshiba Satellite L875-S7110 with Windows 8 that is a few months old now, and had been working fantastic until last night. Windows did an update, and now I have a red X over my sound icon that states "No Audio Output Device is installed." Things I have tried so far to try...
I'll put this edit at the top, so that you won't have to read the rest if you don't want to. I fixed the problem by restoring my system to a restore point created the day I got the computer set up. I'll have to reinstall everything I've put on it in this last week, but that's better than sending...
Hi, I have a compaq presario V6500 which came installed with Windows Vista. I recently upgraded my OS to Windows 8 (last month). Today, just like that, the sound was lost, while I was listening to a tutorial online. The sound icon on the desktop taskbar says "No Audio Output Device is...
