Win8.1/Ubuntu dual boot... sound issue only after OS swap
    8.1 pro + Ubuntu
    I have 8.1 and Ubuntu in dual boot.
    Sound works perfectly until...... I restart from Ubuntu and load Windows... then I have to put Windows to sleep and wake up again to get the sound to work.... right pain in the rectum it is....
    Does we know how to fix this anyone please...?
    Nick
    I set Windows hibernate off to prevent conflicts between the OS' - it results in slower boot time but on an SSD it's not that much of a problem.
    8.1 pro + Ubuntu
    Having just tried a process of elimination by trying all variables I can narrow it down.
    It ONLY happens if I choose Restart from Ubuntu.... Shutdown and start from power button choosing to boot Windows doesn't result in the issue.
    Also.... the issue is ONLY at the speaker jack.... if i unplug the extension speakers the sound is working thru laptop speakers perfectly and I assume that is why Device Manager is reporting all is working fine.
    Seems that restart from Ubuntu is shutting down my ext jack plug in Windows... until I put windows to sleep and reawaken.
    The plot thickens..........................
    registry key missing/corrupt maybe....?????
    Hi
    How did you configured the dual boot ?. Is it legacy or UEFI mode ?.
    8.1 pro + Ubuntu
    My BIOS is Phoenix version 07PA and has a selection which reads 'UEFI support' and in the definition pane states "if enabled will allow booting to BIOS OS or UEFI OS"... that's exactly how it's written.... which seems a bit odd as most new machines have CSM or UEFI with a secure boot function.... this Samsung with the phoenix BIOS doesn't offer those choices.
    I can run the dual boot with the UEFI support enabled or disabled.... same audio issue
    been reading a thread on Superuser where someone else faced this issue.... apparently Ubuntu makes a mess of the Windows audio drivers and the end result was 'it can't be fixed'.... .... Can't...?... that word does not compute... of course it can be fixed.... what they meant was that there is no-one clever enough to suggest the correct solution available....
    So.... unless someone really clever can suggest how I might fix this I will have to put up with not using restart and instead just shutdown and fire up the machine again to get into Windows from Ubuntu.... extra 10 seconds....
    l can only guess that Ubuntu is shutting down the audio ext speaker jack when restart is selected.... there must surely be a registry key that is responsible for making this happen during the restart process but only relative to windows audio driver
    In that case i assume you have a legacy mode install. I never saw this audio issue before but i have seen Ubuntu causing graphical issues to Windows 7/8.x. That is, you boot to Ubuntu, restart the system and select "Windows 7/8" from the GRUB menu, you may see artifacts from Ubuntu/graphical glitches during the Windows loading animation. So far i have seen this only on laptops and not on any Desktops. In the end i fixed the issue ( on multiple laptops ) by configuring Windows boot manager to dual boot both Windows and Linux together. That is the issue only present when GRUB2 is being used as the boot loader but not when Windows boot manager directly load Windows. Since Windows boot manager can't directly chainload Ubuntu, i have used "EasyBCD" to configure the dual boot.
    However it's a risky process and i don't know whether it will fix your audio issue. So i guess shutdown and then powering again will be the safe root. But if you are willing to experiment, he re is the link to a tutorial which will assist you in configuring the dual boot.
    https://neosmart.net/wiki/easybcd/du.../linux/ubuntu/
    8.1 pro + Ubuntu
    I have EasyBCD on board my Win utilities folder.... tried to change bootloader control... makes no difference to the sound issue
    What it has done is add an extra screen (or 2) for booting purposes.... and in fact when I power on I now get the very pretty GUI Win 8.1/Ubuntu dual boot screen first... before then taking me to a DOS looking screen with same choice.... then finally to the Grub multi choice screen.
    I'll reverse that back to how it was I think and stick with powering off completely to swap out OS without losing sound to my BOSE speakers.
    The only thing I haven't tried is uninstallng audio drivers in Windows and powering off then reinstalling them in case it was Linux install that messed them up..... you know I'll try that.... we hate not finding solution to logical issues.... because there IS a solution !!!
How come the thread has been marked solved? There are several videos on youtube explaining how, here is just one: How to Install Ubuntu 12.04 to Dual boot alongside Windows 8 - YouTube http://www.youtube.com/watch?v=LokDqte3sA4
Hi, I have my Windows 8 installed in my C drive and it is the only OS I have as of now. I want to install Ubuntu 12.04 alongside Windows 8. But I have read so many negative things with regards to problems in booting after installing Ubuntu alongside Windows 8. My Win 8 is installed in UEFI...
I cloned my Windows 7 Pro X64 system to another HDD then upgraded the cloned system to Windows 8 Pro. As a result both Win7 and Win8 have the same Boot Manager Data, so I currently use the BIOS alternate boot option to select which system to boot. Have tried a number of "solutions" so far, but...
Hello, I have an HP Envy with Win8 pre-installed. I am trying to do a dual boot setup with windows 7, as some of the software I use daily, is not compatible with win8. The new software has yet to be released, and will not run in any compatibility modes. Knowing this is beating a dead horse,...
Win8 Win7 dual boot issue in Installation & Setup
I have a new windows8 preloaded laptop, and I found a tutorial on this forum on how to dual boot with win7. Im not sure if windows8 has anything to do with it, but when I boot to the DVD to install windows7, it ends up just sitting at the start up splash screen saying "starting windows". I...
dual boot with ubuntu in Installation & Setup
So I have this lenovo ideacentre B540 All-in-one that originally came with Windows 7. The customer bought it at best buy and it came with a free upgrade to Windows 8 when it came out. So the customer was using it with Windows 8 until he got some FBI porn virus on there. I was hired to reload...
I finally downloaded and installed Windows 8 on my computer today. It has 3 hard drives, an SSD that has Windows 7, and two other drives that have media and other stuff. I shrank one of these volumes and created a new 50 GB partition for Windows 8. The install seemed to be without any glitches...
