Audio Service Not Running
    I tried to modify things from services tring to activate audio but no hope, and when i troubleshoot i get this message
    [IMG]res://sdiageng.dll/print.png[/IMG]
    Issues found
    One or more audio service isn't running
    Both the Windows Audio and the Windows Audio End Point Builder services must be running for audio to work correctly. Atleast one of these services isn't running.
    Not fixed [IMG]res://sdiageng.dll/error.png[/IMG]
    Start required audio services Completed
    Potential issues that were checked
    Check audio device
    Check audio device
    There might be a problem with your audio device.
    Issue not present
    Issues found Detection details
    6 One or more audio service isn't running Not fixed [IMG]res://sdiageng.dll/error.png[/IMG]
    Start the Windows Audio and the Windows Audio End Point Builder services
    Potential issues that were checked Detection details
    Check audio device Issue not present
    Detection details [IMG]res://sdiageng.dll/expand.png[/IMG]
    See this forum thread. If that doesn't fix it, you are looking at a complete reinstall.
    Audio Service is not running; Error 0x800706cc
A few days ago I had a windows update, and after it was done everything seemed fine. I muted my sound later on, and suddenly it wouldnt come back on. When I mouse over it, it says Audio Service is not running. After googling the problem I have done the following to try to fix it: System recovery...
Yesterday I turned on my computer and I was greeted without any sound. I think my computer updated when I went to bed the day before, so I thought that might've been the cause (or maybe it was AVG). So I looked up how to fix it and saw System Restore, tried that and was greeted with this: ...
on my HP all-in-one computer, windows 8.1 was auto installed - the sound worked fine for a day, now it doesnt - also, i cant access the control panel - how can i fix this, and where can i get a free update or audio device?
Solved Audio service not running in Sound & Audio
Hello, i installed windows 8 CP a few days back and i have been facing quite a few problems. The main one being the audio service not working. I tried a lot of solutions that have been given on the internet but its to no avail. When i try to start the windows audio service from the services screen,...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
