Sound card scenario
jago86
Trinidad
My existing audio output jacks on the motherboard look like this:
0
I use the:
Green – Front Right and Front Left
Orange – Centre and Subwoofer
Black – Rear Right and Rear Left
I got the Logitech z-906 5.1 surround sound and the back looks like this:
0
It’s using the three 3.5mm audio jacks that come out the motherboard and go into the corresponding coloured inputs.
The sound card (ASUS STXII 7.1 )that I wanna get has these outputs except as RCA outputs ( it consists of two cards, one main card and a daughterboard)
0
If I get three of these 3.5 mm to RCA connectors, and plug them into the outputs of the sound card and into the inputs of the z906 will it convert the sound properly, in terms of left and right and specifically centre and subwoofer?
0
Hope this illustrates what i would like to do in order to achieve surround sound from the sound card.
0
Any thoughts would be greatly appreciated.
    Windows 8.1 Pro x64
    My Build
    AMD FX 8350 4 Ghz (Stock speed) 95W
    ASUS Sabertooth 990FX R2.0
    Kingston 16GB DDR3
    MSI TwinFrozr III nVidia GTX 680 2GB
    RealTek HD Audio - Logitech THX Z906 5.1 Surround Sound - 500W
    Samsung 32" LCD Television - LN32D405E3D
    1360 x 768
    Samsung EVO 840 (OS)
    Seagate 500GB (Miscellaneous) 7200rpm SATA 6
    Hitachi 500GB (Games) @ 7200rpm SATA 6
    Hitachi 1TB (Downloads) 7200rpm SATA 3
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Klip Xtreme Multimedia- KMM 101E
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    i love wantons, sushi, fruit cocktail, pistachio gelato and lemon sorbet
    F1 Savant
That Asus sound card is 7.1 channel, which is 8 discreet channels. The red and white outputs on the motherboard of the Asus are only for front left and right, they only have one channel of information each. I am not aware of an RCA jack that is able to carry more than just one channel of audio information, so your adaptors are going to have to be some kind of Y adaptors.
    Custom
    Intel Haswell i5 4690
    Asus Z97-A
    2 x 8gb HyperX, by Kingston
    None yet
    Outboard USB DAC
    Samsung S24D360
    Custom
    Asus Z97-A
    None yet
    Outboard USB DAC
    Samsung S24D360
Of, by the way, that sound card looks pretty nice.
    Custom
    Asus Z97-A
    None yet
    Outboard USB DAC
    Samsung S24D360
    Windows 8.1 Pro x64
    My Build
    Kingston 16GB DDR3
    1360 x 768
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    F1 Savant
Why do you go for analogue connections? In the year 2015 I personally would not go for anything else than an optical digital output, connected to the amp. That's also the reason why I am sticking to Creative cards. It's not understandable to me why Asus refuses to include an optical digital output. It's the only connection that truly eliminates any sort of distortion.
    Windows 8.1 Update 1
    self built
    AMD FX-8350
    Gigabyte GA-990FXA-UD7 Rev. 3
    16 GB
    Zotac GTX 770 Amp 2 GB
    GDATA Internet Security
I believe that both analog and digital audio cables have their positives and negatives. In the world of high end audio, all most all of the cables are analog because of the bandwidth of analog cables, that an optical cable doesn't even come close to, not by a country mile. But an optical cable does win when it comes to RF interference suppression. It is six of one or half a dozen of the other. And don't get me started on HDMI.
    Custom
    Asus Z97-A
    None yet
    Outboard USB DAC
    Samsung S24D360
If I use the optical out ,wouldn't the z906 do the processing of the sound?
    Windows 8.1 Pro x64
    My Build
    Kingston 16GB DDR3
    1360 x 768
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    F1 Savant
No, it only has a DAC (Digital to Analog Converter), your computer still processes the sound but signal going ti it is digital which DAC turns back into analog to drive speaker thru it's amplifier.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
CountMike, are you sure about that? The only reason I never answered his question is because on some of my digital devices, his premise is absolutely correct. When using any digital cable out of my Blu Ray player, the processing is done by the pre/pro, but when sending analog out of my Blu Ray player the processing is done by my machine. So at this point, without all of his instruction manuals, I would be hesitant to answer either way.
    Custom
    Asus Z97-A
    None yet
    Outboard USB DAC
    Samsung S24D360
Yes, I'm sure. CODEC chip in the computer (integrated or in discrete audio card) are what processes sound either from analog signal from Microphone or otherwise, or SW making it. After that, in normal conditions, it's converted again to analog (using onboard DAC) and uses analog outputs thru jacks to amplifier and ultimately speakers.
Digital output, bypasses onboard DAC and goes to external DAC amplifier which converts to analog, amplifies and sends analog sound to the speakers. It could be thru SP/dif by wire (coax cable) or optical but signal goes to external DAC as digital.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
It depends on what you mean by "processing". If you talk about digital signal processing (DSP) like an equalizer or sampling rate conversions etc. that would be yes, it's still done by your pc/ soundcard, even if you output the sound digitally. But the conversion of the digital signal into the analog signal has to be done by the digital-analog converter (DAC) of your speakers system since it receives a digital signal but needs an analog signal to make the speakers transform it into sound waves that you can hear.
@Rocky: What you say about high end audio and analog connections is theoretically true but in reality completely irrelevant. First if all we talk about PCs as playback devices. Everything that is played by a PC is digital by design. Digital sources come in various formats with specs according to industry standards. A CD for example has a bit depth of 16 bit and a sampling rate of 44.1 khz. This means it can only contain frequencies that are within a bandwidth of 22050 hz per channel, which by the way is the complete spectrum a healthy human being is able to hear. In fact it's even more than almost every adult is able to hear since most adult's max. frequency he or she is able to hear tops out around 16 khz. Digital connections like optical cables are perfectly able to transfer high end signals encoded with up to 24 bit and 192 kzh. There are no commercially relevant digital sources that go beyond those specs. So does it make any sense to talk about the theoretical limitations of digital connections if there are simply no digital sources available (at least not commercially) that exceed those limitations? No matter how good your cables, your amp and your speakers are, they can never sound better than the source. And when it comes to the source we mostly talk about CDs which are limited to 16 bit 44.1 khz. This would be different if we talked about vinyl which is analog. But who with at least some kind of common sense would connect an analog source digitally? This would simply add another conversion analog-digtial. And conversions by design always come with loss of quality. Only problem here, I highly doubt the OP intends to play vinyl through his pc;)
But there is another huge advantage of digital connections, at least if we talk about optical cables: Contrary to every electrical connection like 3.5 mm or cinch cables which can easily be distorted by interferences of other electrical sources optical cables are immune to almost any source of interference. And that's not some theoretical advantage, that's a real world fact, nowadays there are electrical interferences everywhere. Power lines, other audio cables, radio waves, devices of various kinds, you name it.
So I stick to my advice: If the OP's hardware has got the necessary outputs and inputs he would be better off using digital connections, preferably optical SPDIF.
    self built
    AMD FX-8350
    16 GB
Yes, that's what I meant, In case of SPDIF optical or wired, DAC in the speaker system takes role of the DAC in the computer.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
That card comes with adapters that will work with 3.5mm audio cables. You should be fine. That card has a good DAC and the opamps can be swapped out if you have a preference. If your machine is mixed use - games, movies, music - your setup will be fine. If you prefer to game, or just watch movies, optical might be a better bet.
    Intel i7 4790k
    ASUS Z97 Deluxe
    4x8GB Patriot Viper 3 1866
    MSI R9 290X 4GB
    Creative Sound Blaster ZxR / Audioengine A5+
    BenQ XM2730Z
    Samsung 840 Pro 512GB;
    WD Black 4TB;
    WD Velocirapter 300GB
    CoolerMaster 1200
    Corsair Obsidian 650D
    Corsair H100i
    MaxKeyboard Nighthawk X9
    RAT7
    105Mbps / 20Mbps
    Chrome
    Webroot
