headphone works only when i partially plug it
    hello
    i have samsung headphones that came with my NOTE 3 it was working well when i plug it to my laptop
    just today something strange happened
    when i plug it in the laptop only the left one work but the right one doesn't
    if i plug it half way both work well but the microphone doesn't
    N.B : both the right and left sides work well in my mobile when i plug them all the way
    i tried another headphones that works well on other devices and i had the same issue
    can you help
    thanks in advance
    United States
    Windows 8.1 Pro 64-bit
    That's usually a jack problem on the laptop or plug problem on the headphones. Can try blowing out the jack with a can of air. I have even applied rubbing alcohol to the headphone plug before and inserted it a few times. Laptop off of course.
    I worked in an audio store for many years. 90% of the time, the plug is defective. Of course, the easy way to determine is to plug them into another device. If same problem, you have your answer. Unfortunately, with today's molded plugs, the mfr is the only repairor just get a new set.
    United States
    Quote Originally Posted by mrgeek View Post
    Yea, I would try another headphone also.
Hello, Yesterday my headphones broke and the jack is still stuck inside.. there is no way i'm able to get the money for a repair. So i wonder, is there any manual way to disable my sound from going trough the broken (headphone) jack and just let it go trough my built in speakers? (I have a...
My computer is using windows 8.1.1. as part of my backup procedure, I installed the latest Macrum reflect update, then restart as requested. During the restart the Avast! updated without my permission. During restart I observed there the Windows update notification (both right of login screen)...
In WIN 8.1 - unlike past versions that I'm familiar with - I am unable to move individual windows too far off screen without them being forced to minimize. Any fixes? Thanks....
Since about 4 days, I'm having various problems primarily on the internet. Since I myself have no clue of what could cause all of this, I cannot specify anything about the problem itself, but i'll say how it influences me. 1) All sorts of downloads from the internet first load normally,...
So... Basically long story short is that I was trying to install windows 8.1 on my new SSD for my laptop. However during the installation process, I accidentally unplugged the USB drive that had the Windows 8.1 install on it and the process was interrupted. Now whenever I plug in that SSD into...
Mic through headphone in Sound & Audio
Hi. I am having a VERY frustrating issue. I bought a Turtle Beach Earforce PX-21. (link to headset here). I use the headset for chat using teamspeak 3 while playing games. (link to teamspeak here). My motherboard is a ASUS SABERTOOTH 990FX R2.0 (link to motherboard here). The problem is pretty...
