headphone works only when i partially plug it
Zaref
Egypt
hello
i have samsung headphones that came with my NOTE 3 it was working well when i plug it to my laptop
just today something strange happened
when i plug it in the laptop only the left one work but the right one doesn't
if i plug it half way both work well but the microphone doesn't
N.B : both the right and left sides work well in my mobile when i plug them all the way
i tried another headphones that works well on other devices and i had the same issue
can you help
thanks in advance
    Lenovo G580
    Inter Core I5 3210M
    4GB
    Nvidia Geforce 610
    1366*786
    1MBpS
    Avira
    medical student who enjoys gaming
That's usually a jack problem on the laptop or plug problem on the headphones. Can try blowing out the jack with a can of air. I have even applied rubbing alcohol to the headphone plug before and inserted it a few times. Laptop off of course.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
I worked in an audio store for many years. 90% of the time, the plug is defective. Of course, the easy way to determine is to plug them into another device. If same problem, you have your answer. Unfortunately, with today's molded plugs, the mfr is the only repairor just get a new set.
Yea, I would try another headphone also.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
