Sound quiet all of a sudden in headphones.
    So my PC just had a whole bunch of issues which seem unrelated, but there was a massive mess with a system restore and a whole bunch of updates and stuff, but I don't know why all of a sudden my headphones are really quiet, even on the maximum volume setting.
    This is an issue with all sound devices I own. They work fine on other computers by the way, so it's most likely a PC issue.
    Any possible explanation/fix for this?
    N.Y.
    Windows 10 Pro 64bit
    For starters would be helpful to fill in system specs here or list them for us. What were all these other unrelated issues, which updates, windows or hardware,software ? What other spound devices we talking about stereo receiver ? Start by checking settings in software for sound card, then in Windows sound properties.
    It's a windows 8.1 64 bit OS, intel core i5 4670k, 16384 mb of ram, directx11, GTx 670 card.
    Sound: Headphones, HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_14, type: WDM, default device: yes.
    Not sure what else to supply
    The updates installed were about 51 of them, so I don't know what all of them were, but they were a lot of Windows updates. The unrelated issues were that my PC would say "could not install updates, undoing changes" or something like that, then just restart and do the same again. So I did a system restore to March 22nd and then installed those 51 updates. After that my sound has been wonky.
    First, please fill in the "My System Specs", not list them in a post. See mine for example.
    Second, "HDAudio" suggests that only the generic, basic function, Windows sound driver is installed instead of the correct driver for your sound hardware (whatever that is as it is not listed). The correct sound driver may fix the headset problem.
    N.Y.
    Have integrated sound card on motherboard or one in a PCI slot ? True make sure have most up to date drivers for this device, check settings for this device. As said try to fill in system specs from your profile page here.
    I don't know if I have an integrated sound card, under devices and in dxdiag all I can see is my headphones, not info regarding sound card.
    By the way, weird thing but it got fixed by updating the drivers and then reverting back to the old drivers again. Thanks for suggesting checking my drivers.
    N.Y.
    YW, Usually know you will have sound and mic input jacks( or a combination of black, green, orange jack colors) on the back of the PC that integrates into the motherboard, then you have an integrated sound device. Otherwise be a card in a slot horizontally. Headphones are not a sound card, so without a sound device the headphones would not work.
    System specs you filled in are not enough or correct for me to find your motherboard, i see it is a MSI but can not find it online through that model you listed. Believe if drivers are not in there or generic, may not tell you a brand of sound device in DXDIAG. Might just say HD Audio.
    Trnava
    Win 8.1.1 Pro x64
    Your motherboard should have Realtek soundcard onboard, so try this one:
    Download Realtek HD Audio Driver 2.75 64-bit for Windows 8.1 64 bit - Softpedia
I'm running Windows 8.1 and everything's been fine up until two days ago. At least once a day my sound simply stops working for some reason. When I try to make a Skype call or play an mp3 file it says that there is a problem with my playback device. Happens both to headphones and speakers, meaning...
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
I tried to play songs in windows media player but it showed some error. Then i switched to VLC just to find out that there is some problem with the sound. When I clicked on the volume icon to see if the volume levels are ok, I found the computer icon, which appears there to be like as if there is a...
Ok first thing is that I've already been looking for a solution through google and I did come across this: http://i.imgur.com/xmSnqUM.png I changed it to what the picture shows and my volume is still very quiet. I've also checked if my drivers were up to date and they were. The strange thing...
Solved Sound is extremely quiet? in Sound & Audio
So I am wearing headphones, they're plugged into a 3.5 mm speaker. This speaker is plugged into my computer's motherboard. I can hear sound, but it's extremely quiet. My speakers are maxed out. Windows 8 sound is 100%. Youtube video is at 100%. I honestly don't know how to update my...
No sound with headphones? in Sound & Audio
Hey guys, I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
