How can I use Dolby Audio with USB Headphones
    Pelaihari
    Windows 8.1 x64 & Ubuntu 14.10 x64
    Hello guys, I have been searching around about this but they always end up with a headphones that has built-in Dolby Audio. I just bought a USB Headphones and when I use it, the Dolby software always disabled. If I plug in a headset/earphone base on 3.5mm jack the software work again. Does Dolby Audio software only run on a specific hardware? anyway my laptop has built-in Dolby Advanced Audio v2 and the sound card was Conexant SmartAudio.
    Along with this, there is a little more question. The headphones I bought (Dragon War Beast) is a 5.1 channel sound (said on the box & the website). But I honestly confused if it was real or not cuz in Windows Audio it only show stereo channel on Speaker Setup as well as the manual said USB 2.1 Stereo Vibrating Headset (different from the box). Is there a way I can test if its a stereo or 5.1 sound?
    Thanks in advance. Any help is always apreciated, and of course sorry for my bad english
    When you use USB headsets, you bypass the PC's sound card (and add on's such as the Dolby). The USB headset has the "sound card" (conversion from digital to analog) built in.
    The 5.1 is a function of the USB headset and again does use the PC sound. If the source, such as a game, is 5.1 then you will get the 5.1 (simulated) sound. Unless there are multiple speakers in the headset I don't see how it can get "real" 5.1 sound. Its like my LCD HD TV, it has two stereo speakers but simulates surround sound.
    What firebird said is absolutely correct. Let me recap;
    1. When you use the USB jack you are by-passing the audio processing of your computer and using the audio processing of the headphones.
    2. When you use a "standard" headphone jack you are using the audio processing of the computer, which includes your Dolby processing.
    Also, there is no such thing as 5.1 headphones, not on this planet. There are 5.1 compatible headphones, but there is no such thing as 5.1 headphones because that would be a massive device that would contain a sub-woofer and a center speaker somewhere right over the top of your head, not to mention the front and back speakers pointed towards your ears.
    United States
    Windows 8.1 Pro 64-bit
    Would look something like this:
    Pelaihari
    Quote Originally Posted by Rocky View Post
    Well I was wondering how big will the headphones with subwoofer inside How can I use Dolby Audio with USB Headphones
    So, that mean usb headphones comes with it own sound card and Dolby only run on built-in pc sound card (which I think Dolby certified). So there is no way I can get Dolby to work unless I have a headphones with Dolby certified right?
    And for 5.1 channel, I tried to play Dota with Stereo channel and then 5.1 channel. I felt that 5.1 somehow reduces the volume. Is it normal or unsupported by the device?
    Quote Originally Posted by Baskhara View Post
    Maybe you didn't exactly understand. If you get a pair of headphones with a standard "phono" jack you will most certainly be utilizing the internal sound processing of the computer, including the Dolby. firebird was pretty clear that you only by-pass that circuitry when you use USB type headphones.
    Pelaihari
    Ok I got it now! Thanks man for the answer, also for firebird How can I use Dolby Audio with USB Headphones Really helpful for me to understand it How can I use Dolby Audio with USB Headphones
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
I upgraded today to 8.1 and now when I start my computer I get a message box telling me <re-install Dolby advanced audio driver> I found the Dolby program in my control panel, programs and features, and there is no un-installer or, seemingly a way to re-install the driver. I don't want this box...
Hi guys, I'm having an (what appears to be quite a common) issue with my sound since installing to Windows 8.1 I have an Acer Aspire V3-571G laptop, and was recently asked to upgrade to Windows 8.1. Once I did that, a pop-up has come up saying:...
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I canīt open it, and when I try it says that I could re-install it. But how?
Hi, I have an HP Pavillion DV6 3216 US entertainment notebook which does not currently have functioning audio. I have no audio coming through the built in speakers (I've tried fiddling with the playback device options/properties/testing the device to no avail) but do have audio when I plug a pair...
When my Turtlebeach x12 is plugged into my computer (runs Windows 8) and I try to launch some steam games the audio plays through the built-in speakers rather than my headset. I've played around with default devices and disabling/enabling different devices, but nothing has worked. In some games...
