Sound goes up with 4 instead of 2
    BSOD Kernel Dump Analyst
    Windows 10 Pro
    Since a while I have a problem with my sound.
    If I wanted to have my sound a little bit harder it used to go up with 2, but since the problem occured the sound goes up with 4.
    I have a suspicion that the problem is with the program that shows the kind of images below.
    Is there someone who knows a solution?
    This is an annoying and big problem for me, because my ears are pretty sensitive.
    I checked my RealTek HD Audio Manager and there is nothing there to set how loud it gets.
    If you are pressing a key on the keyboard to raise or lower the sound that is a function of the Dell control program.
    Since this is a Dell, best to post on the Dell laptop forum where there are those familiar with the Dell applications.
    http://en.community.dell.com/support-forums/laptop/
    Windows 10 Pro
    Nothing is changed and weird enough the problem is solved...
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Had windows 7, sound worked for quite awhile with my toshiba laptop. Installed the realtek driver and about 2-3 months later the sound stopped working. When plugged into TV w headphone jack it works (at least the last time I did this). I unplugged and the sound worked again for about 2 days and...
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
